Solving net horizontal word problem
In summary, a net horizontal word problem is a mathematical problem that involves finding the net horizontal distance traveled or force acting on an object using equations and concepts from physics. The steps for solving such problems include identifying the unknown variable, drawing a diagram, writing down known values and equations, using the equations to solve for the unknown, and checking the answer. The specific equation(s) to use will depend on the given information and unknown variable, and it is important to avoid common mistakes such as incorrect identification of variables, using the wrong equation, and not checking the answer for accuracy.
dramaqueen
the pathway for a mineshaft is described as follows: The first shaft extends north and down at an angle of 3.5 degree for 225ft to a vertical shaft which 125ft long. A third shaft then extends north and down at an angle 6.8 degree for 175ft. What is the total depth below ground level at the end of the third shaft? Also, what is the net horizontal distance from the ground opening to the end of the third shaft?
I look all over the chapter example and could figure out how to do it...
HELP!
What have you tried to do?
FAQ: Solving net horizontal word problem
What is a net horizontal word problem?
A net horizontal word problem is a type of mathematical problem that involves finding the net horizontal distance traveled or the net horizontal force acting on an object. It typically involves using equations and concepts from physics, such as velocity, acceleration, and force, to solve for the unknown variable.
What are the steps for solving a net horizontal word problem?
The steps for solving a net horizontal word problem include:
1. Identify the unknown variable
2. Draw a diagram to visualize the problem
3. Write down any known values and equations
4. Use the equations to solve for the unknown variable
5. Check your answer to ensure it makes sense in the context of the problem.
How do I know which equation to use in a net horizontal word problem?
The equation(s) to use in a net horizontal word problem will depend on the information given in the problem and the unknown variable. It is important to carefully read the problem and identify the relevant equations for the given situation. Some common equations used in net horizontal word problems include those for velocity, acceleration, and force.
Can I use the same method to solve all net horizontal word problems?
While there are general steps for solving net horizontal word problems, the specific method used may vary depending on the problem. Some problems may require the use of more complex equations or multiple steps to solve. It is important to carefully read and understand each problem before attempting to solve it.
What are some common mistakes to avoid when solving net horizontal word problems?
Some common mistakes to avoid when solving net horizontal word problems include:
- Failing to correctly identify the unknown variable
- Not carefully reading and understanding the problem
- Using the wrong equation or incorrectly applying an equation
- Forgetting to convert units to match
- Not checking the answer for accuracy
It is important to double-check your work and ensure that your answer makes sense in the context of the problem.
