A Solving nonlinear singular differential equations
wasi-uz-zaman
TL;DR Summary
how to tackle singularity in the differential equations
hi, i am going through differential equations which are nonlinear and singular - like Lane-Emden equation etc.
my question is how to tackle singularity - while coding.
regards
What method are you using to solve these equations?
If you solve <br /> \frac{1}{r^{n-1}} \frac{d}{dr}\left(r^{n-1}\frac{d\theta}{dr}\right) = -\theta^m for n = 2 or 3 subject to \theta(0) =1 and \theta&#039;(0) = 0 then there is no difficulty: The singular point is at the origin, but you aren't enforcing the ODE there because \theta and \theta&#039; are fixed by the boundary conditions.
Likes Astronuc and DrClaude
I like to think of the solutions of an ODE as a vector field. @pasmith's answer means to avoid singularities by choosing initial values, i.e. trajectories which lead you through the field without encountering singularities.
If you still consider the entire field, then there are certain types of singularities: attractors, repellers, or intersecting trajectories, maybe even isolated points. Such a classification allows handling different types of singularities differently. It's always the same: what is the situation and what is the goal?
If you approach it numerically, then you have to consider how robust a solution is. This means if you vary the initial values, how much do the trajectories vary? Again a matter of the given situation and goal.
Likes pbuk and PAllen
Yes, I remember the idea of solutions as a vector field being a revelation for me. I was fortunate that this notion was introduced in my initial ODE course.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
