MHB Solving Partial Fractions & Maclaurin Series Q&A
The discussion focuses on solving the partial fraction decomposition of the function f(x) = (x^2 + 7x - 6)/((x - 1)(x - 2)(x + 1)). The partial fractions are determined to be -1/(x - 1) + 4/(x - 2) - 2/(x + 1) through the Heaviside cover-up method. Additionally, the Maclaurin series expansion is derived, showing that for small x, f(x) approximates to -3 + 2x - (3/2)x^2 + (11/4)x^3. The steps include calculating derivatives and applying the series formula. This comprehensive approach aids in understanding similar problems in partial fractions and series expansions.
MarkFL
MHB
Here is the question:
PARTIAL FRACTIONS: How to solve this?
Let f(x) =
(x^2 + 7x − 6)/((x − 1)(x − 2)(x + 1))
(i) Express f(x) in partial fractions.
(ii) Show that, when x is sufficiently small for x4 and higher powers to be neglected,
f(x) = −3 + 2x − (3/2)x^2 + (11/4)x^3.
Please work it out step by step so I can figure out how to work out similar questions on my own.
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Re: Past the Black's question at Yahoo Answers regarding partial fractions and Maclaurin series
Hello Past the Black,
We are given:
$$f(x)=\frac{x^2+7x-6}{(x-1)(x-2)(x+1)}$$
i) We may assume the partial fraction decomposition of $f$ will take the form:
$$\frac{x^2-7x-6}{(x-1)(x-2)(x+1)}=\frac{A}{x-1}+\frac{B}{x-2}+\frac{C}{x+1}$$
Using the Heaviside cover-up method, we find:
$$A=\frac{1^2+7\cdot1-6}{(1-2)(1+1)}=\frac{2}{(-1)(2)}=-1$$
$$B=\frac{2^2+7\cdot2-6}{(2-1)(2+1)}=\frac{12}{(1)(3)}=4$$
$$C=\frac{(-1)^2+7\cdot(-1)-6}{(-1-1)(-1-2)}=\frac{-12}{(-2)(-3)}=-2$$
Hence, we find:
$$f(x)=\frac{x^2-7x-6}{(x-1)(x-2)(x+1)}=-\frac{1}{x-1}+\frac{4}{x-2}-\frac{2}{x+1}$$
ii) The Maclaurin expansion is given by:
$$f(x)=\sum_{k=0}^{\infty}\left[\frac{f^{(k)}(0)}{k!}x^k \right]$$
Using the partial fraction decomposition written in the following form:
$$f(x)=-(x-1)^{-1}+4(x-2)^{-1}-2(x+1)^{-1}$$
We may state:
$$f^{(k)}(0)=(-1)^kk!\left(-(-1)^{-(k+1)}+4(-2)^{-(k+1)}-2 \right)$$
And so the series expansion becomes:
$$f(x)=\sum_{k=0}^{\infty}\left[(-1)^k\left(-(-1)^{-(k+1)}+4(-2)^{-(k+1)}-2 \right)x^k \right]$$
And so the first 4 terms are:
$$f(x)\approx-3+2x-\frac{3}{2}x^2+\frac{11}{4}x^3$$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
