Solving Physics Problem: Moment = F × d = 60X20 = 50d, d = 24 cm
In summary, the equation for calculating moment is Moment = F × d, where F is the force applied and d is the distance from the axis of rotation. To solve for the moment in a problem, the equation can be rearranged to d = Moment / F. The unit for moment is measured in newton-meters (N·m) in the SI system of units. In simpler terms, moment is a measure of the turning effect of a force and is used in various real-world applications such as engineering, construction, and sports.
mutineer123
93
http://www.xtremepapers.com/CIE/International%20A%20And%20AS%20Level/9702%20-%20Physics/9702_s11_qp_13.pdf
question 12
moments=Fd
60X20=50d
d=24cm
Yo forgot the weight of the rod. ehild
Static of Rigid Bodies.
Total sum of Torque=0
[itex]\sum \tau=0[/itex]
find ccw(counterclockwise) and cw(clockwise) torgue about pivot(40cm).
Related to Solving Physics Problem: Moment = F × d = 60X20 = 50d, d = 24 cm
1. What is the equation for calculating moment?
The equation for calculating moment is Moment = F × d, where F is the force applied and d is the distance from the axis of rotation.
2. How do you solve for the moment in this problem?
In this problem, the moment is already given as 60X20. To solve for the distance, we can rearrange the equation to d = Moment / F. Substituting the values, we get d = 60X20 / 50 = 24 cm.
3. What is the unit for moment?
Moment is measured in newton-meters (N·m) in the SI system of units. In other systems, it may be measured in other units such as foot-pounds (ft·lb).
4. Can you explain the concept of moment in simpler terms?
Moment is a measure of the turning effect of a force. It depends on both the magnitude of the force and the distance from the axis of rotation. The larger the force or the farther the distance, the greater the moment.
5. How is moment used in real-world applications?
Moment is used in a variety of real-world applications, such as engineering, construction, and sports. It is essential for designing structures that can withstand forces, such as bridges, buildings, and machines. In sports, moment is important for activities such as throwing, swinging, and lifting.
