MHB Solving Probability Coupling Problems: X & Y
The discussion revolves around solving probability coupling problems involving two independent random variables, X and Y, each uniformly distributed over the set {1,...,6}. For part (a), the probability that X equals Y is calculated as Pr[X = Y] = 6/36, or 1/6, since there are 6 outcomes where X equals Y out of 36 total outcomes. In part (b), the suggestion to set Y equal to X is clarified, emphasizing that simply stating "Y = {X}" is misleading; it should be "Y = X" for Pr[X = Y] to equal 1. For part (c), participants are encouraged to enumerate all possible outcomes to identify a subset where X is greater than Y in 5 out of 6 cases. The thread highlights the importance of clear definitions and systematic approaches in probability problems.
Harambe1
Hi, I'm struggling to understand probability coupling. I have the following problem:
Let X and Y each be uniformly distributed on the discrete set {1,...6} (i.e. the distribution of the roll of 1 fair die).
(a) If X and Y are independent, what is Pr[X = Y]?
(b) Couple X and Y so that Pr[X = Y] = 1.
(c) Couple X and Y so that Pr[X > Y] = 5/6.
I'm not entirely sure where to start and can't find much information on it.
For part (b), would I be right in simply saying "Let X={1,2,...,6} and let Y={X}. Thus, Pr[X = Y] = 1." If so, great but if not where am I going wrong?
Thanks for your help.
Start by drawing up a 2-way table which shows what you can roll from the two dice. How many possibilities are there? How many of those possibilities have the rolls the same?
There are 6 possible outcomes for each of X and Y so there are 36 possible outcomes for (X, Y). In 6 of those X= Y.
For b, you say "let Y= {x}". What are the braces intended to mean here? Why not just "Y= X"?
For the third, write out all 36 possible outcomes. Find a subset containing 6 of those outcomes such that X> Y in 5 of them. It is not necessary that you be able to write a "formula" describing them.
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
