Solving projectile motion problems using Lagrangian mechanics
In summary, solving projectile motion problems using Lagrangian mechanics involves applying the principles of least action to derive the equations of motion. By defining a suitable Lagrangian, which represents the difference between kinetic and potential energy, one can use the Euler-Lagrange equation to obtain the motion's trajectory. This approach simplifies complex systems and allows for easier incorporation of constraints and forces, making it a powerful tool in classical mechanics for analyzing projectiles.
Melkor77
Thread moved from the technical forums to the schoolwork forums
TL;DR Summary: Lagrangian for projectile motion in an inclined plane with negative slope.
I am a bit unsure on how to find the Lagrangian for projectile motion in an inclined plane with negative slope. I can solve it using Newton Mechanics, but am a bit new to lagrangian mechanics. Also could someone tell me about some free resources to learn more about the topic
I am not sure of projectile motion IN a inclined plane you say. Do You mean 2D motion constrained in a slope plane ?
yes, 2d motion constrained in a slope plane
Thanks. Then how about it for xy slope plane,
[tex]L=\frac{1}{2}m(\dot{x}^2+\dot{y}^2) - mg \sin \theta \ y[/tex]
where plus y corresponds to upward slope of angle ##\theta## >0 ?
The Lagrangian does not depend on the slope. It depends only on the kinetic and potential energy.
Note that the shape of the paths that a projectile can take are the same in both cases. The only difference is the valid endpoints.
Likes PhDeezNutz
This is not correct for the situation the OP is describing:
However, you can of course still get the Lagrangian from taking the difference between the kinetic and potential energies.
In general for this type of problems:
  1. Introduce your generalized coordinates.
  2. Write down the typical standard 3D coordinates as a function of the generalized coordinates.
  3. Take the time derivative of the 3D coordinates and insert into ##m\dot{\vec x}^2/2## to get the kinetic energy.
  4. Insert the expression for the 3D coordinates in terms of your generalized coordinates into your expression for the potential to get potential as a function of the generalized coordinates.
  5. Take the difference between kinetic and potential energy and you have the Lagrangian.
Likes anuttarasammyak
 6. Express the constraint condition with method of Lagrange multiplier and add the ##\lambda## term to Lagrangean.
This is what I have gusessed from OP.
The thing is, you don’t need to do this if you follow the procedure I described. This is one of the beauties of generalized coordinates.
I assume my y in post#4 which is not y of xyz and has no constraints would be a kind of it.
FAQ: Solving projectile motion problems using Lagrangian mechanics
What is Lagrangian mechanics and how is it applied to projectile motion?
Lagrangian mechanics is a reformulation of classical mechanics that uses the principle of least action to derive the equations of motion for a system. In the case of projectile motion, we define the Lagrangian as the difference between kinetic energy and potential energy. By applying the Euler-Lagrange equation, we can derive the equations of motion that describe the trajectory of the projectile, taking into account constraints and forces acting on it.
How do you define the Lagrangian for a projectile?
The Lagrangian for a projectile can be defined as L = T - V, where T is the kinetic energy and V is the potential energy. For a projectile of mass m moving with velocity v, the kinetic energy is T = (1/2)mv². The potential energy V can be expressed as V = mgh, where h is the height above a reference point. Thus, the Lagrangian becomes L = (1/2)mv² - mgh.
What are the steps to solve a projectile motion problem using Lagrangian mechanics?
To solve a projectile motion problem using Lagrangian mechanics, follow these steps: 1) Define the generalized coordinates (e.g., x and y positions). 2) Write down the expressions for kinetic and potential energy. 3) Construct the Lagrangian as L = T - V. 4) Apply the Euler-Lagrange equation for each coordinate to derive the equations of motion. 5) Solve the resulting differential equations to find the trajectory of the projectile.
What are the advantages of using Lagrangian mechanics for projectile motion?
Using Lagrangian mechanics for projectile motion has several advantages: it allows for a systematic approach to derive equations of motion, it can easily incorporate constraints, and it is particularly useful in complex systems where traditional Newtonian mechanics may become cumbersome. Additionally, Lagrangian mechanics is more general and can be applied to various coordinate systems, making it versatile for different types of motion.
Can Lagrangian mechanics handle non-conservative forces in projectile motion?
Yes, Lagrangian mechanics can handle non-conservative forces, but it requires modifications. In cases where non-conservative forces (like friction or air resistance) are present, you can use the generalized force approach. The non-conservative forces can be included in the Euler-Lagrange equations by adding a term that accounts for these forces, allowing for a more comprehensive analysis of the projectile's motion.
