MHB Solving Q.7 with Truth Tables: What Is the Right Conclusion?
  • Thread starter Thread starter ertagon2
The discussion centers on solving a logic problem using truth tables, specifically for question 7. The participant successfully completed question 6 and found two matches in their truth table for question 7, leading to confusion about the correct conclusion. It was clarified that having two matches indicates two valid solutions, confirming that exactly one of B and C is a knave, and thus the statement is true. Additionally, it was established that A is a knight in both scenarios, reinforcing that the answer to the second part of the question is also true. The participant's understanding of the problem was validated.
ertagon2
Hi so this is my homework
I had no problems solving q.6 using truth tables. (Please check if right)
But when solving q.7 i was faced with a question.
I got 2 matches in my truth table.
[table="width: 500, class: grid"]
[tr]
[td]A[/td]
[td]B[/td]
[td]C[/td]
[td]A...[/td]
[td]B...[/td]
[td]C...[/td]
[/tr]
[tr]
[td]T[/td]
[td]F[/td]
[td]T[/td]
[td]T[/td]
[td]F[/td]
[td]T[/td]
[/tr]
[tr]
[td]T[/td]
[td]T[/td]
[td]F[/td]
[td]T[/td]
[td]T[/td]
[td]F[/td]
[/tr]
[/table]
I was told by my professor that for answer to be right the right side must give the same result as left.
But now I have two matches (left side=right side) what conclusion do i draw from this ?
ertagon2 said:
Hi so this is my homeworkI had no problems solving q.6 using truth tables. (Please check if right)
[TABLE="class: grid, width: 500"]
[TR]
[TD]A[/TD]
[TD]B[/TD]
[TD]C[/TD]
[TD]A...[/TD]
[TD]B...[/TD]
[TD]C...[/TD]
[/TR]
[TR]
[TD]T[/TD]
[TD]F[/TD]
[TD]T[/TD]
[TD]T[/TD]
[TD]F[/TD]
[TD]T[/TD]
[/TR]
[TR]
[TD]T[/TD]
[TD]T[/TD]
[TD]F[/TD]
[TD]T[/TD]
[TD]T[/TD]
[TD]F[/TD]
[/TR]
[/TABLE]
Hi ertagon2,
Your answer to Q6 is correct.
For Q7, I understand that you copied the two rows corresponding to the two matches; if this is the case, they are correct.
What this means is that there are two solutions to the question of who is a knight and who is a knave.
However, that is not the question you are asked. The first question is about the statement "exactly one of B and C is a knave but you can't tell which".
Note that, in each of the two solutions, it is true that exactly one of B and C is a knave: the first part of the statement is true. Furthermore, as there are two possible solutions (B or C is the knave), it is also true that you can't tell which, and that is the second part of the statement. The answer to the question is therefore "true".
For the second question, note that, in each of the two solutions, A is a knight. The answer is therefore also "true" in this case.
castor28 said:
Hi ertagon2,
Thanks. I just wanted to make sure that my undertstanding is right.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
