Solving QM Problem: Fermi's Golden Rule & Transitional Probability
Fermi's Golden Rule is the correct approach for solving the quantum mechanics problem related to transitional probability. The time-dependent wavefunction for a free particle is expressed as [1/sqrt(L)]*exp(i*p*x/h_bar)*exp(-i*E*t/h_bar), with momentum p and energy E defined in terms of quantum numbers. To find the probability of scattering from right to left, one must calculate the matrix element M = <initial state|V|final state>, where V is the scattering potential. The final state corresponds to a momentum with a negative sign in the exponential. Once M is determined, it can be used in Fermi's Golden Rule to find the transition rate, which quantifies the scattering probability.
ashah99
Consider a free particle of mass m and energy E moving from left to right in onedimension with periodic boundary conditions on length L. This means a planewave (traveling wave) with positive momentum.
Suppose there is perturbation V(x) = w*δ(x-x_0) with x a real number. What is the probability per unit time that the particle is scattered so that it moves from right to left (traveling wave with negative momentum) with energy E after scattering? Compute your answer to lowest nonvanishing order in time-dependent perturbation theory.
transition probability per unit of time = (2*pi)/(h_bar)*(|<f|H'|i>|^2)*p(Ef)
Hello all, I would like some guidance on how to approach/solve the following QM problem.
My thinking is that Fermi's Golden Rule would be used to find the transitional probability. I write down that the time-dependent wavefunction for the free particle is [1/sqrt(L)]*exp(i*p*x/h_bar)*exp(-i*E*t/h_bar), where p is the momentum and E is energy. My understanding is that p = 2*pi*n*h_bar/L and E = p^2/2m. But, now when trying to set up to the probability per unit time that the particle is scattered so that it moves from right to left, I am a bit lost. Any ways to solve would be appreciated.
Fermi's Golden Rule is indeed the appropriate method to solve this question. To set it up, you need to calculate the matrix element between the initial and final states of the particle. The initial state is the momentum eigenstate of the particle, given by [1/sqrt(L)]*exp(i*p*x/h_bar). The final state is the same but with a negative sign in the exponential, which corresponds to a momentum pointing in the opposite direction. The matrix element is given by M = <initial state|V|final state> where V is the scattering potential. This is the probability per unit time that the particle is scattered so that it moves from right to left. Once you have calculated the matrix element, you can plug it into the expression for Fermi's Golden Rule, which gives the transition rate:Rate = (2pi/h_bar)*|M|^2. This is the probability per unit time that the particle is scattered so that it moves from right to left. I hope this helps!
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
