Solving Quadratic Equations: Find k
In summary, a quadratic equation is an equation in the form of ax^2 + bx + c = 0, where a, b, and c are constants and x is the variable. It can be solved using the quadratic formula, factoring, or completing the square. The constant term in a quadratic equation, represented as "k", determines the y-intercept of the corresponding parabola and helps in finding the solutions of the equation. While a quadratic equation can have multiple values of k, we usually look for the specific value that satisfies the equation.
Albert1
1,221
the solutions of :
$x^2+kx+k=0 "
are $ $sin \,\theta \,\,and \,\, cos\, \theta $
please find : $k=?$
Mathematics news on Phys.org
Hello, Albert!
[tex]\text{The solutions of: }\: x^2+kx+k\:=\:0[/tex]
[tex]\text{are }\sin\theta\text{ and }\cos\theta[/tex]
[tex]\text{Find }k.[/tex]
Since [tex]k \,=\,\sin\theta\cos\theta[/tex], we see that: .[tex]|k| \,<\,1.[/tex]
Quadratic Formula: .[tex]x \:=\:\frac{-k \pm \sqrt{k^2-4k}}{2}[/tex]
[tex]\text{Let: }\:\begin{Bmatrix}\sin\theta &=& \frac{-k + \sqrt{k^2-4k}}{2} \\ \cos\theta &=& \frac{-k -\sqrt{k^2-4k}}{2} \end{Bmatrix}[/tex]
[tex]\text{Then: }\:\begin{Bmatrix}\sin^2\theta &=& \frac{2k^2 - 4k + 2k\sqrt{k^2-4k}}{4} \\ \cos^2\theta &=& \frac{2k^2 - 4k - 2k\sqrt{k^2-4k}}{4} \end{Bmatrix}[/tex]
[tex]\text{Add: }\:\sin^2\theta + \cos^2\theta \:=\:\frac{4k^2 - 8k}{4} \:=\:1[/tex]
[tex]\text{And we have: }\:k^2 - 2k - 1\:=\:0[/tex]
[tex]\text{Hence: }\:k \:=\:1\pm\sqrt{2}[/tex][tex]\text{Since }|k| < 1\!:\;k \:=\:1-\sqrt{2}[/tex]
By Vieta's formulas, we have
$$k=\sin\theta \cos\theta$$
$$\sin\theta+\cos\theta=-k$$
Squaring both the sides of second equation,
$$1+2\sin\theta \cos\theta=k^2 \Rightarrow k^2-2k=1 \Rightarrow k^2-2k+1=2 \Rightarrow (k-1)^2=2$$
$$\Rightarrow k=1\pm \sqrt{2}$$
But $|k|<1$, hence, $k=1-\sqrt{2}$.
thanks all for your participation:)
your answers are correct !
As a scientist, it is important to approach problems and equations with a critical and analytical mindset. In this case, we are given a quadratic equation with unknown variable k and are told that the solutions are sin θ and cos θ. Firstly, it is important to note that the solutions of a quadratic equation are typically in the form of x = a, where a is a numerical value. Therefore, stating that the solutions are sin θ and cos θ is not a typical way of representing the solutions of a quadratic equation.
Furthermore, the given information is not enough to solve for the value of k. We need at least one numerical value or additional equation to determine the value of k. Sin θ and cos θ are trigonometric functions and do not provide enough information to solve for k. Without any additional information, it is not possible to find the value of k.
In conclusion, the given information is insufficient to solve for the value of k in the quadratic equation. As a scientist, it is important to critically analyze and question any given information before attempting to solve a problem. We need more information or a different approach to determine the value of k in this equation.
FAQ: Solving Quadratic Equations: Find k
What is a quadratic equation?
A quadratic equation is an equation in the form of ax^2 + bx + c = 0, where a, b, and c are constants and x is the variable. The highest exponent of x in a quadratic equation is 2, which is why it is called a quadratic equation.
How do I solve a quadratic equation?
To solve a quadratic equation, you can use the quadratic formula, which is x = (-b ± √(b^2 - 4ac)) / 2a. You can also solve it by factoring the equation or by completing the square.
What does "k" represent in a quadratic equation?
In a quadratic equation, "k" represents the constant term, which is the term without a variable. It is the value of y when x = 0. In the standard form of a quadratic equation, k is represented as c.
What is the purpose of finding k in a quadratic equation?
Finding k in a quadratic equation helps determine the y-intercept of the parabola represented by the equation. It also helps in graphing the equation and finding the solutions or roots of the equation.
Can a quadratic equation have more than one value of k?
Yes, a quadratic equation can have more than one value of k. This is because there can be multiple parabolas that can pass through the same point on the y-axis, which represents the value of k. However, in most cases, we are looking for the specific value of k that satisfies the given equation.
