Solving recurence T(n)=T(n-1)+O(n lg n)
  • Thread starter kasper_2211
In summary, the conversation is about trying to solve a recurrence T(n)=T(n-1)+O(n lg n) by guessing the solution and using substitution to prove it. The attempt at a solution involves unfolding the recursion and bounding it with an arithmetic series to arrive at a guess of T(n)=O(n^2 lg n). However, the base case fails and the conversation goes on to discuss using induction to prove the guess.
kasper_2211
I am trying to solve this here recurrence : T(n)=T(n-1)+O(n lg n).
I am trying to do it by guessing the solution, and then use substitution to prove it right. I think that I am way off though...
lg n = log_2 n
Intuitively the "height" of the recursion will be h=n-2, i.e there will be n-1 levels. Level 0 has a cost of n lg n and Level n-1 will have cost T(1). If i sum the cost's, and try to bound by an arithmetic series i arrive at a guess of n^2.
Now, by substitution i guess that it will hold for some constant c >= (lg n+n-2)/2
Hmm... Thank's in advance for any help...
Here is a, maybe, better attempt at a solution.
1. Homework Statement
I am trying to do it by guessing the solution, and then use substitution to prove it right. I think that I am way off though...2. Homework Equations
lg n = log_2 n3. The Attempt at a Solution
First i try to 'unfold' the recursion,
T(n) = T(n-1) + c n lg n
= c n lg n + T(n-1)
=c n-1 lg n-1 + T(n-2)
=c n-1 lg n-1 + c n-2 lg n-2 + T(n-3)
= c n-1 lg n-1 + c n-2 lg n-2 + c n-3 lg n-3 + ... + T(1)
Since this is some decreasing series i try to bound it like so,
T(n) = c n lg n + c n-1 lg n-1 + c n-2 lg n-2 + c n-3 lg n-3 + ... + T(1) <= c n lg n + c n lg n + c n lg n + ... + T(1)
Now since there is approximately n terms this becomes,
T(n) <= c n^2 lg n
So my guess is that the solution is T(n) = O(n^2 lg n)
Does the above reasoning make any sense?
So guessing at O(n^2 lg n)
Assuming that T(1) = 1
base case 1 : 1 <= 1 lg 1 = 0 -> fails
base case 2 : T(1) + 2 lg 2 <= 4 lg 2 <=> 2 <= 4 -> OK
Now assume that for 2 <= k < n : T(k) <= c k^2 lg k
Induction, (d is supposed to be the constant hidden inside O(n lg n))
T(n) = T(n-1) + d n lg n
<= c (n-1)^2 lg (n-1) + d n lg n by I.H
<= c n^2 lg n + d n lg nNow I am a little stuck...I guess that somehow in the limit c n^2 lg n + d n lg n <= c n^2 lg n, but i don't think i can use that...Also, it looks almost correct but i need to get rid of the lower order term d n lg n. Is this possible?
FAQ: Solving recurence T(n)=T(n-1)+O(n lg n)
How do you solve a recurrence relation?
To solve a recurrence relation, you need to first identify the pattern of the relation and then use a mathematical technique such as substitution, iteration, or the master theorem to find a closed-form solution.
What is the meaning of O(n lg n) in the given recurrence relation?
O(n lg n) is a notation used in computer science to describe the worst-case time complexity of an algorithm. In this recurrence relation, it represents a time complexity of n multiplied by the logarithm of n.
Can you explain how the recurrence relation T(n)=T(n-1)+O(n lg n) can be solved using substitution?
Substitution is a method for solving recurrence relations by repeatedly substituting the recurrence equation into itself. In this case, by substituting T(n-1) into T(n), we get T(n) = T(n-2) + O((n-1) lg (n-1)) + O(n lg n). This process can be continued until the recurrence relation is in a form that can be solved using simple algebra.
How does the master theorem help in solving recurrence relations?
The master theorem is a mathematical tool used to find a closed-form solution for recurrence relations that follow a specific form. It involves identifying the values of a, b, and c in the recurrence relation T(n) = aT(n/b) + f(n), and then using a set of formulas to determine the time complexity of the algorithm.
Are there any other techniques for solving recurrence relations?
Yes, there are other techniques such as iteration, where the recurrence relation is solved by repeatedly applying the recurrence equation until a pattern can be identified. There is also the method of generating functions, which uses a mathematical tool called generating functions to find a closed-form solution for the recurrence relation.
