MHB Solving Recurrence Relations: Are My Results Right?
The discussion revolves around solving various recurrence relations using the master theorem. The user presents five relations and their corresponding solutions, agreeing with the results for the first four but questioning the application of the theorem to the fifth. They note that the master theorem does not apply to the fifth relation since the function does not meet the necessary conditions. The user suggests that an upper bound version of the master theorem could be used to derive a solution for the fifth relation, proposing that it could yield T(n) = O(n^2 log n). The conversation concludes with uncertainty about the exact bounds for the fifth relation, depending on the behavior of the last term.
mathmari
MHB
Helloo!
I have to solve the following recurrence relations:
(a) T(n)=sqrt(2)*T(n/2)+lgn
(b) T(n)=3*T(n/4)+nlgn
(c) T(n) 3*T(n/3)+n/2
(d) T(n)=5*T(n/2)+Θ(n)
(e) T(n)=9*T(n/3)+O(n^2)
Could you tell me if my results are right?
Using the master theorem I found:
(a)T(n)=Θ(sqrt(n))
(b)T(n)=Θ(nlgn)
(c)T(n)=Θ(nlgn)
(d)T(n)=Θ(n^(log(2)5)
(e)T(n)=Θ(n^2*lgn)
I agree with (a)–(d) using the version of the master theorem in http://www.csail.mit.edu/~thies/6.046-web/master.pdf from MIT, but not in Wikipedia. (The former document is given as a footnote in the Wiki article.) The reason is that Wikipedia uses only Θ and not O or Ω.
However, the theorem does not seem to apply to (e) because $f(n)=O(n^{\log_ba})$. Your answer would be correct by case 2 of the theorem if $f(n)=\Theta(n^{\log_ba})$.
And how could I solve the recurrence relation (e)?
I am pretty sure there is an upper bound version of the master theorem, which says, in particular:
If $T(n) = aT(n/b) + f(n)$ where $f(n) = O(n^{\log_ba})$, then $T(n)=O(n^{\log_ba}\log n)$,
but I am having trouble finding exactly this formulation. http://www.eecis.udel.edu/~saunders/courses/621/11s/notes/notes/Master-theorem.html seems to say something pretty close. It also should be easy to change the proof from Θ to O.
If this is correct, then $T(n) = O(n^2\log n)$ in (e). I am not sure one can say more because if the last term is, in fact, $n^2$, then $T(n)=\Theta(n^2\log n)$, but if it is 0, then $T(n)=\Theta(n^2)$.
Ok! Thanks!
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
