Solving Refraction Problems: Calculating Refractive Index of Glass and Juice
  • Thread starter jsmith613
  • Tags
    Refraction
In summary, a ray of light passing through a prism was measured to have a critical angle of 41 degrees for the glass-air boundary. Using the formula 1/sin(c) = n1/n2, where n1 is the refractive index of the less optically dense medium and n2 is the refractive index of the denser medium, the refractive index of the glass was calculated to be 1.52. In the second part, where the light passed through glass and then juice, the critical angle for the glass-juice interface was 64 degrees. Using the same formula, the refractive index of the juice was calculated to be 1.69.
jsmith613
614
A ray of light is passed through a prism and the critical angle is measured
a) If the critical angle for the glass-air boundary is 41 degrees, calculate glasses refractive index
b) the same system as before is used, but this time we measure the refractive index of juice.
If the critical angle of the glass-juice interface is 64 degrees find the refractive index of the juice
NONE GIVEN
I think that for a) I do (1/sin(41)) = 1.52
for b) the refractive index of juice is (1/sin(64)) = 1.11
How do I continue from here?
So: μ of glass-air = 1.52; μ of glass-juice = 1.11
find μ of juice?
thanks
Is there a formula from this point onwards?
Hmmmm, do you know what you are doing when you did this?
" the refractive index of juice is (1/sin(64)) = 1.11 "
And to add on this too:
" (1/sin(41)) = 1.52 "
Yeh
n = 1/sin(c)
c = 41
n = 1/sin(41)
n = 1.52
same for the other one
n = 1/sin(c)
c = 64
n = 1/sin(64)
n = 1.11
Then next would be what does the 1 in 1/ sin(c) represent?
its simply the rule of refraction
Not at all. I simple google search on critical angle will land you this formula:
Sin (c) = n1 / n2, where n1= refractive index of less optically dense, and n2 is the denser.
oh so I just do 1.52/1.11
jsmith,
You need to understand what the formula is telling you and not just blindly throw in the numbers.
Your calculations in part b is wrong in the first place.
Please read through this for a complete understanding on critical angle:
http://en.wikipedia.org/wiki/Total_internal_reflection#Critical_angle"
Also, in part b, the light is traveling from the glass to the juice.
delzac
Delzac said:
jsmith,
delzac
So what is the correct method?
thanks
After reading the wikipedia page, what are your thoughts?
refractive index 1 / refractive index 2 = critical angle
BUT
we don't know refractive index 1 or 2 because you said my equation was wrong?
We know refractive index in air is 1.
In the first example, you are asked to calculate the refractive index of glasss.
Then in part b, you are asked to calculate refractive index of juice.
In each part they gave you critical angle, and you know at least one refractive index.
a) 1/sin(41) = 1.52
b) 1.52 / sin(64) = 1.69
is that correct
FAQ: Solving Refraction Problems: Calculating Refractive Index of Glass and Juice
What is refraction and why is it important in science?
Refraction is the bending of light as it passes through a medium, such as glass or juice. It is important in science because it allows us to understand how light behaves and how it interacts with different materials.
How do you calculate the refractive index of a material?
The refractive index of a material can be calculated by dividing the speed of light in vacuum by the speed of light in the material. This value is unique for each material and can be used to predict the behavior of light as it passes through the material.
What equipment is needed to conduct a refraction experiment?
To conduct a refraction experiment, you will need a light source, a medium to refract the light (such as glass or juice), a protractor, a ruler, and a calculator. Optional equipment may include a laser or a spectrometer for more precise measurements.
What are some real-life applications of understanding refraction?
Understanding refraction is important in many fields, such as optics, medicine, and engineering. It allows us to create corrective lenses for glasses and contacts, design optical instruments like microscopes and telescopes, and even develop medical imaging techniques like MRI and ultrasound.
How can I use my knowledge of refraction to solve real-world problems?
By understanding the principles of refraction, you can use your knowledge to solve problems like correcting vision, designing optical devices, and predicting the behavior of light in different materials. You can also use refraction to explain natural phenomena, such as rainbows or mirages.
