Solving Schrodinger equation in two dimensions
X''(x)-CX(x)=0s^2 - C = 0s = sqrt(C)X(x) = Ae^(sqrt(C)x)+Be^(-sqrt(C)x).In summary, the time independent Schrodinger equation for an electron in a 2-D potential well can be solved by using separation of variables and assuming a separable wavefunction. This leads to two differential equations, one with a function of x and the other with a function of y. By setting the functions equal to constants and solving the resulting equations, the wavefunction can be determined.
90
Solve the time independent Schrodinger equation for an electron in a 2-D potential well having dimensions Lx and Ly in the x and y directions respectively.
d^2Y/dx^2 + d^2Y/dy^2 + 2m/h^2*EY = 0
Y(x) = A exp(jkx) + B exp(-jkx)
I'm not even sure that is correct as a starting point, as that is what is given for the example in the book for the Schrodinger equation in one dimension, not two dimensions.
Is this for a finite well or an infinite well?
Infinite potential well.
Okay, so for [itex]|x|\leq L_x[/itex] and [itex]|y|\leq L_y[/itex] the schroedinger equation reduces to:
[tex]\left(\frac{\partial^2}{\partial x^2}+\frac{\partial^2}{\partial y^2}+\frac{2mE}{\hbar^2}\right)\Psi(x,y)=0[/tex]
right?
Now use separation of variables; assume that [itex]\Psi(x,y)=X(x)Y(y)[/itex]...what do you get when you plug that into Schroedinger's equation?
I forgot how to do separation of variables. How do you do that part?
You assume the wavefunction is separable (i.e. assume [itex]\Psi(x,y)=X(x)Y(y)[/itex])...substitute that into the Schrodinger equation and simplify...what do you get?
I get d^2Y/dx^2 + d^2Y/dy^2 + 2m/h^2*EX(x)Y(y) = 0
But doesn't the substitution also have to be done for the second derivatives? How would that be done?
No, you don't get that. And yes, the second derivatives act on [itex]\psi(x,y)=X(x)Y(y)[/itex]
When you plug in for each of the second derivatives, do you treat the other variable as a constant?
You tell me, how does one usually take the partial derivative of a multivariable function?
I googled it and found out that for multivariable partial derivatives the other variables are held constant.
So is this the answer?
Y(y)X(x)'' + X(x)Y(y)'' + 2m/h^2*E*X(x)Y(y) = 0
Yes.:approve:
Now, what do you get when you divide both sides of the equation by [itex]X(x)Y(y)[/itex]?
X(x)''/X(x) + Y(y)''/Y(y) + 2m/h^2*E = 0
Right, now look carefully at that equation...what variable(s) is the quantity X''(x)/X(x) a function of ? What variable(s) is the quantity Y''(y)/Y(y) a function of? Under what conditions can the add together to get a constant value of [itex]\frac{2mE}{\hbar^2}[/itex]?
X''(x)/X(x) is a function of x and Y''(y)/Y(y) is a function of y.
Are you asking when
will be equal to 2m/h^2*E = 0 ?
If that's the case, then it will happen either when both X(x)''/X(x) and Y(y)''/Y(y) are equal to 0, or when X(x)''/X(x) = -Y(y)''/Y(y).
Right, and 'x' and 'y' are independent variables, right?
Are you asking when
No, I'm asking when X(x)''/X(x) + Y(y)''/Y(y) can equal -2m/h^2*E? How can a function of 'x' added to a function of 'y' result in a constant?
Yes, x and y are independent. A function of x and a function of y added together will result in a constant when the variables cancel each other out or become 0.
Well, the variables can't cancel each other out, since they are independent.
What if both functions are constants?
If both functions are constant, then adding them together would result in a constant, but I don't see how they can be constants since they have variables in them.
Are you telling me that you don't consider f(x)=1 to be a function of x? But you do consider f(x)=0 to be a function of x?
I just remembered that they can be constants since they are second derivatives. A variable can disappear when taking derivatives.
Even if they weren't derivatives, a function of a variable can be equal to a constant...I'm not sure why you would think otherwise.
Anyways, yes they must be equal to some unknown constants...so, let's say X''(x)/X(x)=C, what does that make Y''(y)/Y(y)...do you know how to solve these two differential equations?
Yes, functions of a variable can be equal to a constant, I just suspected that wasn't the case here.
If X''(x)/X(x) = C, then X(x)''/X(x) + Y(y)''/Y(y) = -2m/h^2*E
C + Y(y)''/Y(y) = -2m/h^2*E
Y(y)''/Y(y) = -2m/h^2*E - C
If that is correct, then I think that the integral should be taken twice. However, I don't think that I know how to do that as the Y(y) on the bottom makes things more complicated.
Right, now X''(x)/X(x)=C means X''(x)-CX(x)=0 right?...Surely you know how to solve a 2nd order linear, homogeneous ODE with constant coefficients? This is 1st year calc stuff...
It's been a while so I'm not too confident with solving the ODE. I think that I have to create a characteristic equation, and I'll find solutions s1 and s2, and plug that into an equation like Ae^(s1)+Be^(s2), then plugin initial values to find A and B? Is it something like that?
Yes, exactly like that...Now just crack open your old calc textbook, review the section on constant coefficient ODEs and get to it...
X'' - CX = 0
r^2 - C = 0
r^2 = C
r1 = C
r2 = -C
X = Ae^(Cx) + Be^(-Cx)
Is that much correct? Now do I plugin initial and final conditions to solve for the constants, or do I first have to find the particular solution?
Ermm... if [itex]r^2=C[/itex], doesn't that mean [itex]r=\pm\sqrt{C}[/itex]?...And you'll want to look at 3 different cases: (1) [itex]C\equiv k^2>0[/itex]; (2) [itex]C\equiv-k^2<0[/itex]; and (3) [itex]C=0[/itex]...what do the general solutions look like in each case?
X = Ae^(sqrt(C)x) + Be^(-sqrt(C)x)
if C = k^2 then the equation is
X = Ae^(kx) + Be^(-kx)
if C = -k^2 then it is
X = Ae^(ikx) + Be^(-ikx) (not sure about this one)
if C = 0 then it is
X = Ae^0 + Be^0 = A + B
Right.
Also correct, but it is more useful if you write it in the form X(x)=Asin(kx)+BCos(kx)
if C = 0 then it is
No, if C=0 then your ODE becomes X''(x)=0...just integrate twice...what do you get?
  • #31
How is it that X = Ae^(ikx) + Be^(-ikx) is the same as X(x)=Asin(kx)+BCos(kx)? Is there a name for that rule?
If C = 0, I don't see why that doesn't turn
into
X = Ae^0 + Be^0
Just plug in right?
  • #32
Just use Euler's formula and rename the constants to A and B when you are done...you should be familiar with this form of the solution, by now...it is VERY VERY VERY common in physics, and you can verify that it satisfies the ODE just by differentiating it twice.
into
X = Ae^0 + Be^0
Just plug in right?
If C=0, your characteristic equation has a single eigenvalue of r=0, with multiplicity of 2, so the form of your general solution will be different (Remember, your ODE is second order, so you expect to have two linearly independent solutions, a constant is only one solution)...
  • #33
So if C = 0, then
r1 = r2 = 0
so the equation is
X = Ae^(sqrt(C)x)+Bxe^(sqrt(C)x)
X = Ae^0 + B(0)e^0
X = Ae^0
X = A
Is that right?
  • #34
No, re-read the section of your calc book that deals with repeated roots to the characteristic equation...
  • #35
Can I just skip over to X''(x)=0, and then integrate twice to solve for X?
Then that becomes X'(x) = X + C1
X(x) = XC2 + C1
