I Solving Schrodinger's eqn using ladder operators for potential V
Hamiltonian
The Schrodinger equation:
$$-\frac{\hbar^2}{2m} \frac{d^2\psi}{dx^2} + \hat V\psi = E\psi$$
$$\frac{1}{2m}[\hat p^2 + 2m\hat V ]\psi = E\psi$$
The ladder operators:
$$\hat a_\pm = \frac{1}{\sqrt{2m}}[\hat p \pm i\sqrt{2m\hat V}]$$
$$\hat a_\pm \hat a_\mp = \frac{1}{2m}[\hat p^2 + (2m\hat V) \mp i\sqrt{2m}[\hat p,\hat V ^{1/2}]]$$
The Hamiltonian:
$$\hat H = \frac{1}{2m}[\hat p^2 +2m\hat V]$$
The Hamiltonian in terms of the ladder operator:
$$\hat H = \hat a_\pm \hat a_\mp \pm {\frac{i}{\sqrt{2m}} [\hat p, \hat V^{1/2}]} $$
finding ##\hat H(\hat a_- \psi)##:
$$\hat H(\hat a_- \psi) = [\hat a_-\hat a_+ \frac{i}{\sqrt{2m}}[\hat p, \hat V^{1/2}]](\hat a_- \psi)$$
$$\hat H(\hat a_- \psi) = \hat a_-[E - \frac{2i}{\sqrt{2m}}[\hat p, \hat V^{1/2}]](\psi)$$
If we apply the lowering operator repeatedly we will eventually reach a state with energy less than zero, which do not exist.
$$\hat a_- \psi_0 = 0$$
$$[\hat p - i(2m\hat V)^{1/2}]\psi_0 = 0$$
$$[-i\hbar\frac{d}{dx} -i \sqrt{2mV(x)}]\psi_0 = 0$$
$$\psi_0(x) = -\int {\frac{\sqrt{2mV(x)}}{\hbar}dx}$$
$$\psi_n(x) = A_n(\hat a_+)^n \psi_0(x)$$
where ##\psi_0## is the ground state wave function solution.
Is this a correct way to give a general solution of the Schrodinger equation for any potential?
You can quickly check whether you have a general solution by trying it on the special case ##V=0##. Try this and you’ll likely see that the harmonic oscillator potential has a property required for this approach to work that is not found in more general potentials.
Likes gentzen, Demystifier and BvU
I made a small error here, ##\psi_0## is supposed to be:
$$\psi_0(x) = e^{\int -\frac{\sqrt{2mV(x)}}{\hbar} dx}$$
Is there a way to account for the case where ##V(x) = 0##?
Leaving aside this case the final siltion should hold true for any arbitrary potential ##V(x)##?
The "lowering operators" do not really lower energy. Instead, they multiply ##\psi(x)## by a function that depends on ##x## (except in the cases ##V=0## and ##V\propto x^2##), so it cannot be interpreted as a number times ##\psi(x)## .
This technique is pretty much restricted to the harmonic oscillator and the angular-momentum eigenvalue problems, and the latter is even also reducible to the symmetric harmonic-oscillator problem in 2 dimensions. So one can expect that most of the problems, where this "factorization of the Hamiltonian" approach works, is due to symmetries reducing to the harmonic oscillators in ##d## dimensions and thus related to the Lie algebras of the SU(d) groups. Schrödinger has written (at least) two papers about this too:
https://www.jstor.org/stable/20490744
https://www.jstor.org/stable/20490756
Likes BvU and Hamiltonian
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
