MHB Solving Sequence Problem with Elementary Math Concepts
  • Thread starter Thread starter anemone
    Sequence
The discussion centers on simplifying a sequence problem involving fractions for a 9-year-old. The sequence includes fractions that repeat in a structured manner, with each block having a constant sum of numerators and denominators. To find the fifth occurrence of the fraction equivalent to 3/7, it is first converted to 15/35, indicating it lies in the 49th block of the sequence. The position of this fraction is calculated to be 1211, derived from understanding triangular numbers and the structure of the sequence. The goal is to present the solution in a way that is accessible and understandable for a child.
anemone
MHB
POTW Director
Hi MHB,
My nephew, age 9, was asked the following question and he hoped I could solve the problem and then explain the solution to him using only elementary math concepts. My boyfriend has solved it, but he used a formula that he recalled seeing in a textbook by G.H. Hardy, and that involved knowledge of triangular numbers.
So, I don't know how to attack this problem from a 9 year old's perspective. If you happen to know how to simplify the problem, could you please enlighten me? Many thanks in advance.
Problem:
In the sequence of fractions $\dfrac{1}{1},\,\dfrac{2}{1},\,\dfrac{1}{2},\, \dfrac{3}{1},\,\dfrac{2}{2},\,\dfrac{1}{3},\, \dfrac{4}{1},\,\dfrac{3}{2},\,\dfrac{2}{3},\, \dfrac{1}{4},\, \dfrac{5}{1},\, \dfrac{4}{2},\, \dfrac{3}{3},\, \dfrac{2}{4},\,\dfrac{1}{5}\cdots$, fractions equivalent to any given fraction occur many times. For example, fractions equivalent to $\dfrac{1}{2}$ occur for the first two times in positions 3 and 14. In what position is the fifth occurrence of a fraction equivalent to $\dfrac{3}{7}$?
Mathematics news on Phys.org
anemone said:
Hi MHB,
Problem:
Hello.(Whew)(Whew)
Let \ \dfrac{A_n}{B_m}
Let \ n=order \ number \ suscession \ numerator
Let \ x=number \ numerator
And:
Let \ m=order \ number \ suscession \ denominator
Let \ y=number \ denominator
Then:
x \ number \ position=\dfrac{n^2+(2x-1)n+x^2-3x+2}{2}. (1)
y \ number \ position=\dfrac{m^2+(2y-3)m+y^2-y+2}{2}. (2)
Making: x=m \ and \ y=n \rightarrow{}x \ number \ position=y \ number \ position
Example:
\dfrac{3}{7}=\dfrac{15}{35}
therefore:
x=15 \ and \ y=35
For (1): x \ number \ position=\dfrac{35^2+(2*15-1)35+15^2-3*15+2}{2}=1211
Same:
For (2): y \ number \ position=\dfrac{15^2+(2*35-3)15+35^2-35+2}{2}=1211
I had done a 'programme', showing how works this topic, but I have not been able to attach the file of Excel.(Headbang)Regards.
anemone said:
Hi MHB,
Problem:
Let's suppose to call $a_{n}$ the sequence at numerator and $b_{n}$ the sequence at denominator. It will be $a_{n}=3$ for $n = 4\ m + \frac {(m-1)\ (m-2)}{2}, m=1,2,...$ and $b_{n}=7$ for $k = 7\ (k+3) + \frac{(k-1)\ (k-2)}{2}, k=1,2,...$. By systematic search You find that is $a_{n}=3,\ b_{n} = 7$ for $k=3,\ m=7, n=43 $ and no other values of n. The succcesive search is dedicated to find the value of n for which is $a_{n}=6,\ b_{n}= 14$ and then the value of n for which $a_{n}=9,\ b_{n} = 21$ and so on, so that the solution of the problem is the value of n for which $a_{n}=15,\ b_{n}=35$. That is a little hard task for an old wolf like me but I'm sure that You will find the number n with no difficulties (Wink)...
Kind regards
$\chi$ $\sigma$
anemone said:
Hi MHB,
Problem:
I think this is a hard problem for a nine-year-old. The first step is to see that the fifth occurrence of a fraction equivalent to $\dfrac{3}{7}$ is the fraction$\dfrac{3\times5}{7\times5} = \dfrac{15}{35}.$
The given sequence consists of blocks of terms in which the sum of the numerator and denominator is constant. The series starts with a single term for which that sum is $2$. Then there is a block of two terms where the sum is $3$, a block of three terms where the sum is $4$, and so on. Within each block, the terms are ordered by their denominator. The first term in the block has denominator $1$, then $2$, and so on.
For the fraction $\dfrac{15}{35}$, the sum of the numerator and denominator is $15+35 = 50$, so it lies in the $49$th block. It will be the $35$th term in that block, so it will be $35$ places beyond the end of the $48$th block.
At this stage, I think that you are inevitably going to get drawn into the realm of triangular numbers. Somehow or other, you have to convince yourself that the $48$th block ends at the term whose position in the sequence is $\frac12\times 48\times 49 = 1176.$ It then follows that the fraction $\dfrac{15}{35}$ occurs at place $1176 + 35 = 1211.$
The average nine-year-old would probably find that argument too difficult to follow. But I am sure that a relative of anemone would relish it. (Wink)
Edit. To convince someone inexperienced in algebra to believe the formula $\frac12n(n+1)$ for the $n$th triangular number, I would draw an $n\times(n+1)$ array like this:
Code:
You can see from this that half of the $n(n+1)$ elements are $+$s, and also that the number of $+$s is $1+2+3+\ldots + n$.
Hi mente oscura and chisigma,
Thanks for your replies and I understand what both of you are saying, but for this problem, I have to solve it using the simplest way possible since it is a problem for my nephew, not me...if it were up to me to solve it, then I would attack it as I would attack a ferocious tiger in the forest, hehehe...:)
Hi Opalg,
Thank you so so much for the easy to follow explanation! I appreciate it from the bottom of my heart. I will also tell my nephew who Opalg is and also let him know you are someone I hold in the highest esteem. (Sun)
You can be sure that I am your number one "fan" on earth! (heart)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
9K
