Solving Simultaneous Equations: 4x + 5y =12 and -8x + 4y =32
The discussion revolves around solving the simultaneous equations 4x + 5y = 12 and -8x + 4y = 32. The initial attempt involved multiplying the equations to align the y coefficients, leading to incorrect subtraction and an erroneous value for x (4.666...). The correct approach was identified as subtracting the top equation from the bottom, yielding the correct solution for x (-2). Participants emphasized the importance of careful arithmetic and suggested writing out steps to avoid mistakes. The conversation highlighted various methods for solving simultaneous equations, including matrix representation.
paulb203
Solve the following simultaneous equation;
4x + 5y =12
-8x + 4y =32
I multiplied the top one by 4, and the bottom one by 5 to make the y coefficients the same and got;
16x + 20y = 48
-40x + 20y = 160
Then I subtracted the bottom one from the top one and got;
-24 x = -112
Which gave x = 4.666...
But the answer for x was -2
I realise now that if I had subtracted the the top one from the bottom I would have got;
-56x = 112, which would give the correct answer for x (x = -2)
But I'm left thinking that the other way should have worked yet I ended up with 4.666... for x
Where did I go wrong when I did it the first way?
matthewphilip said:
Homework Statement:: Solve the following simultaneous equation;
Relevant Equations:: 4x + 5y =12
-8x + 4y =32
16x + 20y = 48
-40x + 20y = 160
-24 x = -112
This is wrong. Subtracting the bottom from the top goes:
(16x+20y-(-40x+20y))=16x+20y+40x-20y=56x=48-160=-112\text{ and }x=-2
A general hint: Write out as much as you can. Writing is faster than thinking and mistakes are easier to trace. Here are the rest of my hints:
https://www.physicsforums.com/insights/10-math-tips-save-time-avoid-mistakes/
Likes berkeman, topsquark and paulb203
Ah! Thank you. When I should have done 16x - (-40x) I incorrectly did 16x - 40x, yeah?
And thanks for the tips too. Bookmarked for later.
-8x + 4y =32
16x + 20y = 48
-40x + 20y = 160
-24 x = -112
You could have too, multiplied the top equation by 2 and add it to the one in the bottom:
8x+10y=24
-8x+4y=32.
... or you could have written the coefficients as ##\begin{bmatrix}4&5\\-8&4\end{bmatrix}## then swap ##4## and ##4##, set a minus sign in front of the non-diagonal elements and get ##\begin{bmatrix}4&-5\\8&4\end{bmatrix}##, calculate ##4\cdot 4 - (-8)\cdot 5=56## and compute
\begin{bmatrix}x\\y\end{bmatrix}=\dfrac{1}{56} \cdot \begin{bmatrix}4&-5\\8&4\end{bmatrix}\cdot \begin{bmatrix}12\\32\end{bmatrix}=\dfrac{1}{56}\begin{bmatrix}4\cdot 12-5\cdot 32\\8\cdot 12+4\cdot 32\end{bmatrix}=\begin{bmatrix}-112\\ 224\end{bmatrix}=\begin{bmatrix}-2\\4\end{bmatrix}
Looks a bit complicated and unnecessarily long, but has the big advantage that it always works, as long as there is a unique solution.
