Solving Sour Milk Problem: Find Least Tasting Bottles
  • MHB
  • Thread starter OhMyMarkov
In summary, the probability of a bottle being sour is $P[X=1] = p_1$. The probability of a bottle being sour is $P[X=2] = (p_1 + p_2)$.
OhMyMarkov
83
Hello everyone!
I'm confusing conditional and joint probability again, here is the problem:
Given 4 bottles of milk, one of them is sour. We need to find out which of the bottles is sour by tasting the least number of bottles. By inspection, we can roughly tell the probability of every bottle being sour. Therefore we rank the bottles in non-ascending order of probability that the bottle is sour. Assume that these probabilities are $p_1, p_2, p_3,$ and $p_4$.
We also define an RV $X$ that is equal to the number of bottles we taste before determining what bottle is sour: $X\in\{1,2,3\}$.
Here is where I'm confused:
$P\{X=1\}=P\{b_1 \text{bad}\}=p_1$
Now, which of the following is correct?
(1) $P\{X=2\}=P\{b_2 \text{bad} \; | \; b_1 \text{good}\}$, $P\{X=3\}=P\{b_3 \text{bad} \;|\; b_1, b_2 \text{good}\}$
(2) $P\{X=2\}=P\{b_2 \text{bad and} \; b_1 \text{good}\}$, $P\{X=3\}=P\{b_3 \text{bad} \; \text{and} \; b_1 \text{good and} \; b_2 \text{good}\}$
Thanks!:eek:
Hi there,
Can you clean up your notation please? It's hard to follow and I see you tried to use a Latex command but it's not rendering. The way I see this written most often is in the following way \(\displaystyle P \left[ X=x \right]\). To see how I wrote that you can quote this post and copy the Latex code. I think if you make a couple quick edits the question will be much more likely to be answered.
Jameson
I've been thinking over this for a bit and I'm not certain I have a full solution but hopefully some helpful comments.
$P[B_n]$ is the probability that the sour milk is located in the nth container. From the OP the order of the bottles is always $(B_1, B_2, B_3,B_4)$ with corresponding probabilities of $P[B_1] < P[B_2] < P[B_3]<P[B_4]$. The sum of these four probabilities is 1.
$P[X=1]=P[B_1]$ if the first bottle is sour.
What does $P[X=2]$ mean? It means that the first bottle was not sour and the second one was. You could write this as $P[B_2|(B_1)']$ but this isn't necessary because there can be just one success in the experiment before it's finished. All of the probabilities correspond to the three other bottles not being sour by the conditions of the situation so because of that I don't think finding $P[X=2,3,4]$ will involve conditional formulas.
When X=2 the only way that happens is bottle 1 to not be sour and then bottle two is so it seems that \(\displaystyle P[X=2]=P[(B_1)'] \cap P[B_2]\) or the second choice you posted.
This seems correct but I wouldn't be shocked if I have not accounted for something. Forcing the order that we choose the bottles is a restriction so it makes sense that the probabilities where failures are counted before the success should be smaller than the chance of it just being sour.
Hopefully there is something useful here for you and sorry in advance if there turn out to be errors.
FAQ: Solving Sour Milk Problem: Find Least Tasting Bottles
How does the sour milk problem occur?
The sour milk problem occurs when bacteria in the milk break down the lactose, producing lactic acid which gives the milk a sour taste. This process is accelerated when milk is stored at room temperature or left out of the refrigerator for extended periods of time.
How can I tell if my milk has gone bad?
The most obvious sign that milk has gone bad is the sour taste and smell. Other indicators include curdling, clumps, and a change in color or consistency. It is important to always check the expiration date and properly store milk in the refrigerator to prevent it from spoiling.
How do I find the least tasting bottles of milk?
The best way to find the least tasting bottles of milk is to conduct a taste test. Start by labeling each bottle with a number and then have a group of people taste each one and rate them on a scale. This will help identify which bottles have the least amount of sour taste. You can also use a pH test kit to measure the acidity of each bottle.
Can I prevent the sour milk problem?
Yes, there are several ways to prevent the sour milk problem. The most effective way is to always store milk in the refrigerator at a temperature below 40°F (4°C). This slows down the growth of bacteria and extends the shelf life of the milk. It is also important to check the expiration date and consume the milk before it goes bad.
Is it safe to drink milk that tastes sour?
In most cases, it is not safe to drink milk that tastes sour. The sour taste is an indication that the milk has spoiled and may contain harmful bacteria. Consuming spoiled milk can lead to food poisoning and other health issues. It is best to discard any milk that tastes sour and always check the expiration date before consuming.
11K
