Solving specific heat problem with two materials
In summary: Glad I could help.In summary, the conversation discussed the process of heating water by adding a hot brick to it. The energy available from the brick was calculated and it was then determined that the heat would flow from the brick to the water, causing both materials to change temperature. The final temperature of the water was found to be 23.9 degrees Celsius. This was further demonstrated through a similar example where two bodies of water were mixed together, resulting in a final temperature of 20.4 degrees Celsius.
HDTeach
Imagine I have a 3.5 kg brick at 80 °C that I put in 10l of water at 20 °C. What will the final temperature of the water be?
SHC brick = 840 J kg-1 °C -1
E = mc∆θ
First I calculated the energy available from the brick to heat the water:
E = mc∆θ = 3.5*840*(80-20) = 176400J
Then I attempted to calculate the temperature change:
E = mc∆θ(for brick)+mc∆θ (for water)
176400 = 3.5*840*(80-∆θ) + 10*4200*(∆θ-20)
176400 = 2940(80-∆θ) + 42000(∆θ-20)
176400 – (2940*80) – (42000*-20) = (2940*-∆θ) + (42000*∆θ)
622440 = 39060*∆θ
∆θ = 16 degrees C
I am not sure this is correct though...any ideas? Have I over-complicated this?
Hi HDTeach,
Welcome to Physics Forums!
E = mc∆θ
This would be the amount of heat that the brick gives up to bring its temperature down to 20C. Do you expect the brick to cool down all the way to the same value as that of the water's initial temperature?
The above equation shows both the water and brick giving up heat (they are being added together). Is that what happens when the materials come together? Or, does heat flow from one to the other?
622440 = 39060*∆θ
∆θ = 16 degrees C
Ask yourself if it makes sense that dropping a hot brick into room temperature water would cool the water (16 < 20).
No, you've just misunderstood how the heat is moving and so wrote an incorrect equation.
Heat will flow from the brick and to the water, cooling one and warning the other. The process stops when the temperature difference between the materials is zero, which will be at some temperature lying between their starting temperatures.
The trick is to write the ∆T's for each so that they incorporate the initial temperature and final (unknown) temperature for each material, and know that heat energy is conserved: One gains the same amount of heat as the other loses.
Thank you! So would it be more like:
E = mc∆T = 3.5*840*(80-T) = 10*4200*(T-20)
235200 - 2940T = 42000T - 840000
1075200 = 44940T
T = 0.4 degrees C?
1075200 = 44940T
T = 0.4 degrees C?
It looks good except for the final value. Redo your final calculation.
Haha oops yes I see the error!
T = 23.9 degrees C
Thank you for your help. I had a worked example that confused me - is this correct in your view?
Question:
1.5 l of water from a kettle at 90°C is mixed with a bucket of cold water (10 l at 10 °C) to warm it up for washing a car.
Find the temperature of the mixed water, assuming no significant heat loss during the mixing. c of water = 4.2 kJ kg-1 °C -1
Answer:
If there is no heat loss and no work done then the total energy of the system at the end is the same as at the start. Working with temperature differences from 10°C we have:
Initial energy = m c ΔT = 1.5 x 4200 x (90-10) [as 1.5 l has mass 1.5 kg] = 504 kJ
This is the amount of energy available to raise the temperature of all 11.5 l of water. Hence:
504 x 1000 = 11.5 x 4200 x (T-10) [where T is the final temperature]
T = 20.4°C
Yes. They took advantage of the fact that the two things being brought together were made of the same material and so had the same specific heat.
Thank you, I just worked it out using the other method and got the same answer so it makes sense to me now! Thank you for all of your help :)
You're welcome!
Related to Solving specific heat problem with two materials
1. What is specific heat and why is it important in solving problems with two materials?
Specific heat is the amount of heat energy required to raise the temperature of a substance by one degree Celsius. It is important in solving problems with two materials because it helps us understand how heat is transferred between the two materials and how their temperatures will change.
2. How do you calculate the specific heat of a material?
The specific heat of a material can be calculated by dividing the amount of heat energy transferred to the material by the mass of the material and the change in temperature. The formula is Q = mcΔT, where Q is the heat energy, m is the mass, c is the specific heat, and ΔT is the change in temperature.
3. What information do you need to solve a specific heat problem with two materials?
To solve a specific heat problem with two materials, you will need the mass, specific heat, and initial and final temperatures of both materials. This information can be used to determine the amount of heat energy transferred between the two materials.
4. Can the specific heat of a material change?
Yes, the specific heat of a material can change depending on its physical state, temperature, and composition. For example, the specific heat of water is higher than the specific heat of ice, and the specific heat of a gas is generally lower than that of a solid or liquid.
5. How can solving specific heat problems with two materials be applied in real life?
Solving specific heat problems with two materials can be applied in many real-life situations, such as determining the amount of heat needed to heat a swimming pool or calculating the energy required to cool a room. It can also be used in industrial processes, such as designing heating and cooling systems for buildings or calculating the amount of heat energy needed for chemical reactions.
