CalcYouLater
- 54
A point charge is located outside of a grounded conducting sphere. Find the potential outside the sphere.
This problem was a solved example. It was solved by placing an image charge inside the sphere so that the potential from the charge outside the sphere would cancel the potential from the charge inside the sphere at the surface of the sphere.
The follow up question is:
By adding a second image charge the same method used above will handle the case of a sphere at any potential V_0. What charge should you use, and where should you put it?
It seems that by exploiting the principle of superposition, an easy solution is to add another image charge at the center. Then that charge would have to be q= 4*Pi*epsilon*R*V_0. Where "R" is the radius of the sphere.
But is that the only possible choice? Since the conductor is an equipotential, doesn't that mean that I could place the added charge anywhere inside the sphere? If so, then it seems the only problem that remains is determining what that charge would be.
