Solving system of differential equations using elimination method
In summary, solving a system of differential equations using the elimination method involves manipulating the equations to eliminate one variable, allowing for simpler integration of the remaining variable. This process typically includes rearranging the equations, differentiating as needed, and substituting to isolate variables. Once a single equation is solved, the solution can be substituted back to find the other variables, ultimately leading to the complete solution of the system. This method is particularly useful for linear systems and can also extend to nonlinear systems under certain conditions.
berlinvic
$$\begin{cases}
y'_1 = y_2, \\
y'_2 = -y_1 + \frac{1}{\cos x}
\end{cases}$$
Elimination method for differential equations, associated homogeneous equation
I am trying to solve this system of differential equations using elimination method, but I am stuck.
$$\begin{cases}
y'_1 = y_2, \\
\end{cases}$$
Here's what I tried:
I've been suggested to differentiate the ##y_1'= y_2## again to get ##y_1''= y_2'= -y_1+ \frac{1}{\cos(x)}##. The "associated homogeneous equation". However, I don't really see a way how to go forward. Anyways, how do you solve this sytem?
That’s just a second order linear homogeneous differential equation. It can be solved by any appropriate method.
Wouldn't the linear homogeneous diff. equation be ##y_1'' + y_1 = 0##? The ##\frac 1 {\cos(x)}## term makes it nonhomogeneous.
Yes sorry, I meant to say inhomogeneous …
Likes Mark44
But I don't see how I can solve ##y_1^{\prime\prime}=y_2^{\prime}=-y_1+\frac1{\cos(x)}## using elimination method. Any help? I get the same answer as using https://mathdf.com/dif/, which, according to my professor, is incorrect.
You already eliminated ##y_2## ….
Yes, but I still can't see how to move forward, I am just stuck at this line.
@berlinvic, did you get a solution for the homogeneous problem ##y_1'' + y_1 = 0##? That's an easy one. For the nonhomogeneous problem ##y_1'' + y_1 = \sec(x)##, you might have to use variation of parameters.
Yes, I should have mentioned, I already know I should use variation of parameters. However I am not entirely sure which ones and how to apply them. I am fairly confused about it, do you have any tips?
Here is everything I've got so far:
I reduced the system to the second order ODE
y_1''+y_1=\frac{1}{\cos x}. \tag{1}
Next steps:
1. Find two linearly independent solutions to the homogeneous equation ##y_1''+y_1=0## --- for instance, ##u(x)=\cos x## and ##v(x)=\sin x##;
2. Compute the Wronskian of those solutions:
W[u,v]=uv'-u'v; \tag{2}
3. Find a particular solution to the equation $(1)$ using the [formula](https://en.wikipedia.org/wiki/Variation_of_parameters#General_second-order_equation)
y_{1p}(x)=A(x)u(x)+B(x)v(x), \tag{3}
where
A(x)=-\int\frac{v(x)}{W(x)\cos x}\,dx,\qquad
B(x)=\int\frac{u(x)}{W(x)\cos x}\,dx; \tag{4}
4. The general solution to ##(1)## is given by
y_1(x)=c_1u(x)+c_2v(x)+y_{1p}(x); \tag{5}
5. To find ##y_2(x)##, use the first equation of the system:
y_2(x)=y_1'(x)=c_1u'(x)+c_2v'(x)+y_{1p}'(x). \tag{6}$$
Next steps:
What did you get for the Wronksian? It's pretty simple in this problem.
where
I think you're confusing yourself with the above notation. The same wiki page you quoted gives these formulas for A(x) and B(x):
##A(x) = -\int \frac 1 W u_1(x)f(x)dx##
##B(x) = \int \frac 1 W u_2(x)f(x)dx##
Here W is the Wronskian and ##u_1(x)## and ##u_2(x)## are the solutions to the homogeneous DE you found earlier.
