albertrichardf
- 165
- 11
Hi,
so I came across this video: which shows an interesting way to solve the Basel problem using lighthouses. Imagine a lighthouse that has absolute brightness 1. The apparent brightness then follows an inverse-square law. Now imagine an infinite number line with positive integers only (and 0), with a lighthouse at each integer. The Basel problem then becomes: find the apparent brightness at the 0 point. This is simple enough. Now in the comments, I found this:
from Copperbotte.
And I can make neither heads nor tails of it. Anyone has an idea of what this means, or how Gauss's law can solve the Basel problem?
Thanks for answering.
You can also use Gauss's law to approach the same solution, rather than a geometric approach. Gauss's law works since a radially symmetric field that's magnitude weakens via the inverse square law has its radius term fall out in a surface integral. This means no matter where the lighthouses are within a sphere of radius R, they can be represented by a single lighthouse of combined magnitude in its center. This also means that same combined lighthouse can be represented by equally spaced, equally lit lighthouses along its boundary. By using this law within a cylinder, and holding the "lighthouse surface density" to be 1/2, you find the surface integral to equal to π^2, and a quarter of the cylinder is π^2/4, the same result as using the geometric method. (The circle is quartered to eliminate lighthouses on the negative side of the number line, and double counting when the number line curves upwards to form the circle)
from Copperbotte.
