Solving the differential equation m^2 = 0?
In summary: The approach is to guess some sort of solution to the DE. It's not actually a substitution.A good guess to try is one that makes every term in the DE contain the same function.This particular guess is suggested by ##\sum_n r^{n-1}\frac{d^n u}{dr^n}=0## and works because ##r^{n-1}r^{m-n}=r^{m-1}## ... i.e. the same function for every term in the DE.Basically - when you see a DE in that pattern, it is likely that u is a polynomial (but may not be).
Nat3
69
I have a problem that starts with the equation:
[itex]r\frac{d^2u}{dr^2} + \frac{du}{dr} = 0 [/itex]
The solution I'm looking at says to do a substitution, letting [itex]u = r^m[/itex], which after differentiation and simplification results in:
[itex]m^2 = 0 [/itex]
Up until this point, I understand (well, actually I don't understand how to know to do this substitution, but I understand how the differentiation and simplification happened), but then the next step says that because [itex]m^2 = 0[/itex]:
[itex]u(r) = c_1 + c_2 lnr [/itex]
Question 1: How do you know to choose [itex]u = r^m[/itex] as the substitution?
Question 2: Why was that form of a solution chosen?
Question 3: Is there a name for this type of substitution and solution?
Thank you!
Actually, that wouldn't have my first suggestion. I would have said let ##y = u'## making the equation ##ry' + y = 0## and notice that ##ry'+y=(ry)' = 0## so ##ry = C## and ##y = u' = \frac C r##. Hence ##u = C\ln r + D##.
If you multiply the original equation by ##r## so it looks like ##r^2u'' + ru' = 0## it becomes an Euler equation for which a standard method would be to try ##r^m##, if you have studied those.
Likes 1 person
(1) The approach is to guess some sort of solution to the DE. It's not actually a substitution.
[ref Euler equation]
(2) $$r\frac{d^2 u}{dr^2}+\frac{du}{dr}=0\\
u(r)=r^{m}\implies [m(m-1)+m]=0\\
\therefore m^2 = 0$$... which tells you that u=1 (or any constant) is a solution ... if somewhat trivial.
So the guess is unhelpful.
Try to think of something else. i.e. notice that the LHS in the DE is a product-rule expansion:
$$r\frac{d^2 u}{dr^2}+\frac{du}{dr}=\frac{d}{dr}\left( r\frac{du}{dr}\right)\\
\frac{d}{dr}\left( r\frac{du}{dr}\right)=0\implies\cdots$$
(3) it's called "trial and error" ;)
IIRC: In the case where a guess of the form u=rm for the above form of DE fails, the solution must therefore be of form u=a+b.ln|r|.
Thanks for your reply LCKurtz!
In your solution, [itex]C[/itex] and [itex]D[/itex] are not constants, like they are in [itex]u(r) = c_1 + c_2 lnr[/itex], correct?
We haven't studied Euler equations as far as I can remember, which is probably why I'm so confused! Is [itex]u(r) = c_1 + c_2 lnr[/itex] a standard solution for a Euler equation?
I'm really confused how to jump from a characteristic equation of [itex]m^2 = 0[/itex] to [itex]u(r) = c_1 + c_2 lnr[/itex]...
C and D are constants just like yours - it's common to use caps for the arbitrary constants in DE solutions.
The jump is because it is always the case when m=0 so you just remember it like you jump from seeing six rows of seven objects to knowing you have 42 objects.
note: LaTeX can format many functions better if you put a backslash in front of the function abbreviation ... i.e. \ln|r| gets you ##\ln|r|##. Also works for log, exp, sin, arcsin, etc.
Likes 1 person
##C## and ##D## are constants.
For constant coefficient DE's you may recall that when the characteristic equation has a double root ##r = \{c,c\}## you have solutions of ##e^{cx}## and ##xe^{cx}##. When you study Euler equations you will learn that when you have a double root of ##r = \{c,c\}## when you try ##x^r##, you get solutions ##x^c## and ##x^c\ln x##. Your text will probably show you why when you get to that section.
Likes 1 person
FAQ: Solving the differential equation m^2 = 0?
What is a differential equation?
A differential equation is a mathematical equation that describes how a quantity changes over time or space. It involves derivatives, which are rates of change, and can be used to model a wide range of physical phenomena.
What is the general solution to the differential equation m^2 = 0?
The general solution to this differential equation is m = 0. This means that any value of m that satisfies the equation is a solution. However, it is important to also consider any boundary conditions or initial values that may be present.
How is a differential equation solved?
There are various methods for solving differential equations, depending on the type and complexity of the equation. Some common methods include separation of variables, substitution, and using integrating factors. In some cases, numerical methods may also be used.
What is the significance of solving the differential equation m^2 = 0?
Solving this differential equation can provide important insights into the behavior of a physical system. It can help predict how a quantity will change over time or space, and can be used to make predictions or solve real-world problems.
Can the differential equation m^2 = 0 have multiple solutions?
No, this differential equation only has one solution, which is m = 0. However, if the equation were to include additional terms or parameters, it could potentially have multiple solutions.
