MHB Solving the Equation cos (x)=-0.8
  • Thread starter Thread starter fordy2707
The discussion focuses on solving the equation cos(x) = -0.8 within the interval [0, 6π]. The initial calculations incorrectly state that x = 143°, which should be clarified as x ≈ 143.13° and converted to radians for accuracy. Participants emphasize the importance of using radian mode on calculators to obtain precise values, with the correct angles in radians being approximately 2.4981 and 3.7851. Additional solutions can be derived by adding multiples of 2π to these angles to find all valid solutions within the specified interval. The conversation highlights the significance of proper angle measurement and conversion in trigonometric equations.
fordy2707
Hi all,just wondering if someone could cast an eye over this,
find all the solutions to the following equation at intervals 0,6$\pi$
cos (x)= -0.8
= $143^{\circ}$
my answer by using the quadrant chart
= 180$^{\circ}$-143$^{\circ}$= $37^{\circ}$
= 180$^{\circ}$ + 37$^{\circ}$ = 217$^{\circ}$
so
= $143^{\circ}$ x $\pi$ / 180
= 143$\pi$ / 180
+2$\pi$= 503$\pi$ / 180
+2$\pi$ = 863$\pi$ / 180
and the 2nd set of solutions
=217$^{\circ}$ x $\pi$ / 180
=217 $\pi$ / 180
+2$\pi$=577 $\pi$ /180
+2$\pi$ =937$\pi$ /180
I was wondering about my answers as the fraction figures seem very large
Mathematics news on Phys.org
I would look at the symmetry of the solutions about $x=2k\pi$ where $k\in\mathbb{Z}$ to write:
$$x=2k\pi\pm\arccos\left(-\frac{4}{5}\right)$$
And so on the given interval, we find:
$$x=0+\arccos\left(-\frac{4}{5}\right)\approx2.498091544796509$$
$$x=2\pi-\arccos\left(-\frac{4}{5}\right)\approx3.7850937623830774$$
$$x=2\pi+\arccos\left(-\frac{4}{5}\right)\approx8.781276851976095$$
$$x=4\pi-\arccos\left(-\frac{4}{5}\right)\approx10.068279069562664$$
$$x=4\pi+\arccos\left(-\frac{4}{5}\right)\approx15.064462159155681$$
$$x=6\pi-\arccos\left(-\frac{4}{5}\right)\approx16.35146437674225$$
cos (x)= -0.8
= $143^{\circ}$
To begin with this says that "cos(x)= $143^{\circ}$" which is nonsense. You mean to say "x= $143^{\circ}$" although I would say that was incorrect because x is clearly supposed to be in radians, not degrees. And, of course, "143 degrees" is not correct because it does not include the decimal part. x is approximately $143^{\circ}$ though that is not a very good approximation.
[/tex]my answer by using the quadrant chart
so
= 143$\pi$ / 180
=217 $\pi$ / 180
937/180= 5.2055... which is less than 6 and you were asked about values less that $6\pi$.
However, I would have set my calculator to radian measure to begin with. Is there any reason you took this "detour" through degrees? You would get a much more accurate answer since you just ignored the decimal part of the degree measure.
HallsofIvy said:
To begin with this says that "cos(x)= $143^{\circ}$" which is nonsense. You mean to say "x= $143^{\circ}$" although I would say that was incorrect because x is clearly supposed to be in radians, not degrees. And, of course, "143 degrees" is not correct because it does not include the decimal part. x is approximately $143^{\circ}$ though that is not a very good approximation.937/180= 5.2055... which is less than 6 and you were asked about values less that $6\pi$.
I see ,its just the way I was shown ,
I thought 143.1301024 would be rounded up to 143 degrees is this not correct ?
$\frac{143\pi}{180}$ = 2.49582083
and 143.1301024 x $\pi$ = 449.6564782 and when divided by 180 to get radians =2.498091546 would It not be deemed at the same answer when rounded up to 2.5 for example
can you show me how you would have gone about this ? thanks
first, it helps to visualize the two angles between $0$ and $2\pi$ where the cosine value is $-0.8$
Note that angles with a negative value for cosine are in quadrants II and III. In the attached diagram, the terminal sides of angles $\theta$ and $\phi$ intersect the unit circle at $x = -0.8$
The inverse cosine function on your calculator will yield angle values in quadrant I for positive values of cosine, and in quadrant II for negative values of cosine. So, if you type $\cos^{-1}(-0.8)$ into your calculator (in radian mode), the calculator will output $\approx 2.4981$ radians, which is the radian measure for angle $\theta$ in the diagram. You may want to use the "store" feature of your calculator to keep the more accurate approximate value.
To get angle $\phi$ in quadrant III, calculate $2\pi - \cos^{-1}(-0.8) \approx 3.7851$ radians
Now all you have to do is add $2\pi$ and $4\pi$ to both $\theta$ and $\phi$ to get all six angles in the interval $(0,6\pi)$ where the cosine's value is $-0.8$View attachment 5953
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 23 ·
