siyanor
- 8
I have an equation which answered it in two ways,which one is correct ?View attachment 163
siyanor said:I have an equation which answered it in two ways,which one is correct ?
https://www.physicsforums.com/attachments/163
siyanor said:I have an equation which answered it in two ways,which one is correct ?https://www.physicsforums.com/attachments/163
To solve an equation with two answers, you will need to use algebraic techniques to isolate the variable on one side of the equation and the constants on the other side. Once the variable is isolated, you can solve for it using basic mathematical operations.
Yes, an equation can have an infinite number of solutions. This typically occurs when the equation contains variables with exponents or when the equation is a quadratic with multiple solutions.
You can check if your answers are correct by plugging them back into the original equation and seeing if the equation is balanced. If both sides of the equation are equal, then your answers are correct.
If the equation has no solutions, it means that there is no value for the variable that will make the equation true. This can occur if there is a mistake in the equation or if the equation is inconsistent.
In some cases, you may be able to solve an equation without using algebra by using graphical or numerical methods. However, for most equations with two answers, algebraic techniques are the most efficient and accurate method for solving.
