MHB Solving the Heat Equation with B.C. and I.C.
  • Thread starter Thread starter Dustinsfl
    Heat Heat equation
Dustinsfl
Is this correct?
\text{B.C.}=\begin{cases}
T_x(0,t) = 0\\
T(\pi,t) = 1
\end{cases}
The I.C. is $T(x,0) = 0$.
The equation is $\frac{1}{\alpha}T_t = T_{xx}$.$$
\varphi(x) = A\cos\lambda x + B\frac{\sin\lambda x}{\lambda}
and
\psi(t) = C\exp\left(-\alpha\lambda^2t\right).
First, let's solve the steady state solution, $\varphi_{\text{ss}}'' = 0\Rightarrow\varphi_{\text{ss}} = ax + b$.
From the boundary conditions, we have that $\varphi_{\text{ss}}' = a = 0$ and $\varphi_{\text{ss}} = b = 1$.
So
\varphi_{\text{ss}}(x) = 1
which satisfy both boundary conditions.
Next, let's solve the transient problem.
Then we have that $\varphi' = -\lambda A\sin\lambda x + B\cos\lambda x$.
Using the homogeneous boundary condition, we have that $B = 0$.
So we are left with $\varphi(x) = A\cos\lambda x$.
Next, we have
\cos\lambda L = 0\Rightarrow\lambda = \left(n + \frac{1}{2}\right)\frac{\pi}{L},\quad n\in\mathbb{Z}^+.
Our general solution is of the form
T(x,t) = 1 + \sum_{n = 1}^{\infty}A_n\cos\left[\left(n + \frac{1}{2}\right)\frac{\pi x}{L}\right]\exp\left[-\alpha\left(n + \frac{1}{2}\right)^2\frac{\pi^2}{L^2}t\right].
Using the initial condition, we have $\int_0^{\pi}[f(x) - 1]\cos\left[\left(n + \frac{1}{2}\right)\frac{\pi x}{L}\right]dx = \frac{L}{2}A_n\iff A_n = (-1)^n\frac{4}{\pi(2n + 1)}$.
Finally, we have that the solution to heat equation with the prescribed is
T(x,t) = 1 + \frac{4}{\pi}\sum_{n = 1}^{\infty}\frac{(-1)^n}{2n + 1}\cos\left[\left(n + \frac{1}{2}\right)\frac{\pi x}{L}\right]\exp\left[-\alpha\left(n + \frac{1}{2}\right)^2\frac{\pi^2}{L^2}t\right].
For the special case of when $\alpha = 1$ and $L = \pi$, we have
T(x,t) = 1 + \frac{4}{\pi}\sum_{n = 1}^{\infty}\frac{(-1)^n}{2n + 1}\cos\left[\left(n + \frac{1}{2}\right)x\right]\exp\left[-\left(n + \frac{1}{2}\right)^2t\right].
Assuming this is correct. How do I plot a sequence of the temperature profiles between the initial state and the steady-state?
Would this be it?
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
