Solving the Integral of sqrt{x^2+1} Using Substitution
  • MHB
  • Thread starter karush
  • Tags
    Integral
In summary, the integral $\displaystyle \int\sqrt{x^2+1}\ dx$ can be solved by using the substitution $u=x$ and $a=1$, which leads to the expression $\displaystyle \frac{u}{2}\sqrt{u^2+a^2} + \frac{a^2}{2}\ln\left| u+\sqrt{u^2+a^2}\right|$. This method involves using hyperbolic trigonometric identities and the inverse hyperbolic sine function.
karush
MHB
3,269
I know this was done before on this forum but can't find it
$\displaystyle \int\sqrt{x^2+1}\ dx%$
$\text{where $u=x$ and $a=1$ then plug}$
how is this derived?
Re: int sqrt{x^2+1}
Let's begin with:
\(\displaystyle I=\int\sqrt{u^2+a^2}\,du\)
Now, consider the hyperbolic trig. identity:
\(\displaystyle \cosh^2(x)=\sinh^2(x)+1\)
Hence, for some positive real constant $a$, we have:
\(\displaystyle a^2\cosh^2(x)=a^2\sinh^2(x)+a^2\)
And so if we use:
\(\displaystyle u=a\sinh(x)\implies du=a\cosh(x)\)
The integral becomes:
\(\displaystyle I=a^2\int \cosh^2(x)\,dx\)
Next, consider the identiy:
\(\displaystyle \cosh^2(x)=\frac{\cosh(2x)+1}{2}\)
And our integral becomes:
\(\displaystyle I=\frac{a^2}{2}\int \cosh(2x)+1\,dx=\frac{a^2}{2}\left(\frac{1}{2}\sinh(2x)+x\right)+C\)
Next, consider the identity:
\(\displaystyle \sinh(2x)=2\sinh(x)\cosh(x)\)
and an implication of a previously used identity:
\(\displaystyle \cosh(x)=\sqrt{\sinh^2(x)+1}\)
And we have:
\(\displaystyle I=\frac{a^2}{2}\left(\sinh(x)\sqrt{\sinh^2(x)+1}+x\right)+C\)
Back-substitute for $x$:
\(\displaystyle I=\frac{a^2}{2}\left(\frac{u}{a}\sqrt{\left(\frac{u}{a}\right)^2+1}+\arsinh\left(\frac{u}{a}\right)\right)+C\)
\(\displaystyle I=\frac{u}{2}\sqrt{u^2+a^2}+\frac{a^2}{2}\arsinh\left(\frac{u}{a}\right)+C\)
Now, consider the identity:
\(\displaystyle \arsinh(x)=\ln\left(x+\sqrt{x^2+1}\right)\)
And we have:
\(\displaystyle I=\frac{u}{2}\sqrt{u^2+a^2}+\frac{a^2}{2}\ln\left(\frac{u}{a}+\sqrt{\left(\frac{u}{a}\right)^2+1}\right)+C\)
\(\displaystyle I=\frac{u}{2}\sqrt{u^2+a^2}+\frac{a^2}{2}\ln\left(u+\sqrt{u^2+a^2}\right)-\frac{a^2}{2}\ln(a)+C\)
Since \(\displaystyle \frac{a^2}{2}\ln(a)\) is a constant, we may write:
\(\displaystyle I=\frac{u}{2}\sqrt{u^2+a^2}+\frac{a^2}{2}\ln\left(u+\sqrt{u^2+a^2}\right)+C\)
very helpful
I can see now why its a plug in equation
i tried it for a few steps but I lost the trail thru the woods
FAQ: Solving the Integral of sqrt{x^2+1} Using Substitution
What is the integral of sqrt{x^2+1}?
The integral of sqrt{x^2+1} is equal to (1/2)*(x*sqrt{x^2+1}+ln|x+sqrt{x^2+1}|) + C, where C is the constant of integration.
What is the domain of the function sqrt{x^2+1}?
The domain of the function sqrt{x^2+1} is all real numbers.
Why is the integral of sqrt{x^2+1} important?
The integral of sqrt{x^2+1} is important because it is used in various fields of science and engineering, such as calculating work done by a variable force, calculating the arc length of a curve, and finding the center of mass of an object with varying density.
Can the integral of sqrt{x^2+1} be solved using different methods?
Yes, the integral of sqrt{x^2+1} can be solved using different methods such as substitution, integration by parts, and trigonometric substitution. Each method may result in a different form of the solution, but they are all equivalent.
Is there a specific technique for solving integrals of the form sqrt{x^2+1}?
Yes, the technique of trigonometric substitution is commonly used to solve integrals of the form sqrt{x^2+1}. By using trigonometric identities, the integral can be rewritten in terms of trigonometric functions, making it easier to solve.
