Solving the SHM differential equation
The discussion centers on solving a homogeneous linear differential equation related to simple harmonic motion (SHM). Participants explore the transition from one form of the solution to another, specifically from line 5 to line 6, using trigonometric identities and substitutions. Clarifications are provided regarding the arbitrary constants in the general solutions, emphasizing that they can be complex. The conversation also addresses the absence of an imaginary unit in certain expressions, concluding that both forms of the solution are valid despite their different appearances. Overall, the thread highlights the flexibility in representing solutions to SHM equations.
member 731016
Please see below
x(t) = Ae^(αt)
I am trying to solve this homogenous linear differential equation
Since it is linear, I can use the substitution
Which gives,
(line 1)
(line 2)
(line 3)
(line 4)
(line 5)
Which according to Morin's equals,
(line 6)
However, could someone please show me steps how he got from line 5 to 6?
Also was is line 4 is it not:
? In other words, why dose B ≠ A?
Many thanks!
All of the expressions below are general solutions of your equation
  1. ##x=C_1e^{i\omega t}+C_2e^{-i\omega t}##
  2. ##x=A\sin\omega t+B\cos\omega t##
  3. ##x=D\sin(\omega t+\phi)##
You can verify that this is so by substituting in your ODE. Note that each expression has two arbitrary constants that are determined by the initial conditions, usually the values of ##x## and ##\frac{dx}{dt}## at ##t=0## that are appropriate to a particular situation..
You are asking how to go from 5 to 6 which is essentially going from my item 2 to 3. It is more obvious to see how to go from 3 to 2. Once you see that, you can reverse the algebra, if you wish.
Using a well known trig identity for the sine of a sum of angles,
$$D\sin(\omega t+\phi)=D\cos\phi \sin\omega t+D\sin\phi \cos\omega t.$$ If you identify $$A\equiv D\cos\phi~~\text{and}~~B\equiv D\sin\phi,$$you have item 2 above.
Likes member 731016
Thanks for your reply @kuruman ! Why don't you have and imaginary unit when going from line 1 to line 2? I though from Euler's identity it should be:
. However, are you assuming that the constant B accounts for that?
Many thanks!
All arbitrary coefficients are, well, arbitrary which means they could be complex.
Likes member 731016
Ok thank you @kuruman ! I guess that means we could have the coefficient without the imaginary unit, which is cool because even thought the answers look different, they are both correct.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
