Solving Thin Films Interference Problem with Oil and Water | 360nm Thickness
A 360 nm thick oil film with refractive indices of 1.50 for oil and 1.33 for water reflects specific wavelengths of light when illuminated with white light. The relevant equation for determining the wavelengths is 2L = ((m + 1/2) * lambda) / n, where L is the film thickness and n is the refractive index. The calculations indicate that the most strongly reflected wavelengths are approximately 430 nm and 720 nm. The answer choice that matches these results is B) 430 and 720. This solution effectively addresses the thin film interference problem presented.
nabilsaleh
A 360 nm thick oil film floats on the surface of the water. The indices of refraction of the oil and the water are 1.50 and 1.33, respectively. The surface of the oil is illuminated from above at normal incidence with white light. The two wavelengths of light in the 400 nm to 800 nm wavelength band that are most strongly reflected, in nm, are closest to:
A) 410 and 700
B) 430 and 720
C) 450 and 740
D) 470 and 760
E) 490 and 780
this is one of questions that came up in the previous exams but i couldn't solve it and i couldn't find the answer online.
i'm guessing we should use this :
2L=((m+1/2)*lamda)/n
n is the index of refraction
lamda is the wavelength
ans is B
) 430 and 720 2*360 nm = ((m+1/2)*lamda)/1.50lamda = 1280 nm m=4 2L=((m+1/2)*lamda)/n 2L=((4+1/2)*1280/1.33)2L=1523.8 L=761.9 so lamda is 761.9 nm and 1260-761.9=428.1 nm so B) 430 and 720 is the closest ans Thanks in advance.
