A Solving this non-holonomic system using Dirac-Bergmann theory
  • A
  • Thread starter Thread starter andresB
    System Theory
The discussion centers on the application of the Dirac-Bergmann theory to a non-holonomic system, specifically a particle constrained by a non-holonomic equation. The participant attempts to derive equations of motion using the Hamiltonian framework but encounters issues due to the non-invertibility of the constraint matrix, leading to complications in applying the Dirac bracket. A proposed solution involves introducing a second constraint and modifying the Lagrangian, yet this approach does not yield consistent results with standard Lagrangian mechanics. The correct method is suggested to involve imposing the non-holonomic constraint directly on the variations, resulting in a set of equations of motion that align with the expected outcomes. The discussion highlights the challenges of using phase space variables for non-holonomic systems and seeks clarity on the proper application of the Dirac-Bergmann formalism.
andresB
I have read in some books and articles that the Dirac-Bergmann procedure to deal with constraints in phase space does not care about holonomic and Non-holonomic constraints, but I've been unable to find a single example. So, I wanted to test that assertion by solving a simple non-holonomic system.
Consider a particle (#m=1#) subject to the non-holonomic constraint $$\phi_{1}=\dot{y}-z\dot{x}=0.$$
The Lagrangian of the system is the standard one
$$L=\frac{1}{2}\left(\dot{x}^{2}+\dot{y}^{2}+\dot{z}^{2}\right)-V(\mathbf{r}),$$
and it is non-singular as the momentum can be found to be
$$p_{i}=\frac{\partial L}{\partial\dot{x}_{i}}=\dot{x}_{i}.$$
In phase-space, the dynamic is given by the Hamiltonian
$$H=\frac{1}{2}\left(p_{x}^{2}+p_{z}^{2}+p_{z}^{2}\right)+V(\mathbf{r})$$
constrained to obey ##\phi_{1}=\dot{p_{y}}-z\dot{p_{z}}=0##. The time evolution is obtained using the Dirac bracket
$$\dot{F}=\left\{ F,H\right\} _{D}=\left\{ F,H\right\} -\sum_{i,j}\left\{ F,\phi_{i}\right\} \left(M_{ij}\right)^{-1}\left\{ \phi_{j},H\right\}, $$
where the Matrix of constraint has the following entries
$$M_{ij}=\left\{ \phi_{i},\phi_{j}\right\}.$$
Now, with only one constraint, the matrix only has one element, and since ##\left\{ \phi_{1},\phi_{1}\right\} =0,## the matrix is non-invertible and there is no Dirac Bracket.
I tried to remedy this in the usual way of the Dirac-Bergmann theory by introducing a second constraint
$$\phi_{2}=\left\{ \phi_{1},H\right\} \approx0$$
But the equations of motion that come from the Dirac bracket do not coincide with the ones from the standard Lagrangian mechanics+Lagrange multipliers method.
So, given the above Hamiltonian and the constraint, how can the correct equation of motion be found?
I don't know the answer to your question but non-holonomic constraints have always intrigued me.
Perhaps @vanhees71 or @wrobel can shed insight.
Apparently, I made a mistake in the statement. The correct procedure is to use the modified Lagrangian
$$L'=L+\lambda\phi,$$
and then the Momenta are given by
$$p_{i}=\frac{\partial L'}{\partial\dot{x}_{i}}=\dot{x}+\lambda\frac{\partial\phi}{\partial\dot{x}_{i}}.$$
In any case, the usual Dirac-Bergmann procedure seems to lead to nowhere.
No! That's leading to vakonomic motion, and that's wrong. We have discussed this at length some time ago in the textbook forum, when this occured in the infamous 3rd edition of the famous mechanics textbook by Goldstein, which was entirely correct in the 1st and 2nd edition, before it was destroyed by some new authors.
The correct treatment is to impose the non-holonomic constraint on the variations (i.e., as in d'Alembert's principle on the "virtual displacements"), i.e., the correct variational ansatz is
$$\int_{t_1}^{t_2} \mathrm{d} t [\delta L+\lambda (\delta y-z \delta x)]=0,$$
where ##\lambda## is a Lagrange parameter. The resulting equations of motion thus are
$$\frac{\partial L}{\partial x}-\frac{\mathrm{d}}{\mathrm{d} t} \frac{\partial L}{\partial \dot{x}} -\lambda z=0,$$
$$\frac{\partial L}{\partial y}-\frac{\mathrm{d}}{\mathrm{d} t} \frac{\partial L}{\partial \dot{y}} +\lambda=0,$$
$$\frac{\partial L}{\partial z}-\frac{\mathrm{d}}{\mathrm{d} t} \frac{\partial L}{\partial \dot{z}}=0,$$
$$\dot{y}-z \dot{x}=0.$$
So you have ##3## coordinates ##(x,y,z)## and ##1## Lagrange multiplier ##\lambda## and ##4## equations, as it should be.
Hi Vanhees,
I'm aware of the correct Lagrange treatment for this system. What I don't know is the how to solve it using phase space variables, and, in particular, I wanted to check the statement that the Dirac bracket formalism can be used to find the correct equation of motions*.
*I'm away from my books at the moment, so i can't quote it, but that's what Petter Mann's Lagrangian and Hamiltonian mechanics seems to say.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
