Solving this system of equations.
In summary, the conversation discusses a personal project involving calibrating values from a sensor input. The individual has been doing the calibrations manually and is now looking for a program to automate the process. They have an equation and a set of values for v, r, g, b, and a, and want to find the best fit values for G, B, and C. The question is whether this is possible and if there are any recommended methods for solving it. Possible approaches include a non-linear optimisation tool or treating it as a probabilistic problem.
jasonc
I have a personal project I'm working on that involves calibrating some values from a sensor input. So far I've been doing the calibrations in a very tedious manner but I'd like to write a program to solve the calibration for me. Very long story very short, this basically boils down to the following:
I have this equation:
I have a set of many v, r, g, b, and a values (v is either 0 or 1, a is a known constant, r g b vary between 0 and 1), and I want to find the best fit values for G, B, and C.
Is this possible? I don't know much about linear equations but I don't think this is one. Can anybody recommend any methods for solving these?
Thanks!
J
Thanks!
J
Hi jasonc, :)
What you have is a system of equations which you have to solve for \(G,\,B,\mbox{ and }C\).
Whenever, \(v=1\),
\[1=\frac{-gG-bB+r-C}{-gG-bB+r-C}\Rightarrow r=a\]
Hence the set of values that you have should meet the criteria, \(r=a\) whenever \(v=1\). Otherwise this system is not soluble.
Whenever, \(v=0\),
\[0=\frac{-gG-bB+r-C}{-gG-bB+r-C}\Rightarrow -gG-bB+r-C=0\]
When you plug in values for \(r,\,g,\,b\) you have a set of equations with three variables, \(G,\,B,\mbox{ and }C\). If you have more than three linearly independent equations then the system doesn't have a solution. If there are exactly three linearly independent equations then the system has a unique solution. If the number of linearly independent equations are less than two the system will have infinitely many solutions.
Kind Regards,
Sudharaka.
Thanks!
J
You want a non-linear optimisation tool that finds the minimum of:
\[ \rm{ Ob(G,B,C)=\sum_i \left|v_i-\frac{-g_iG-b_iB+r_i-C}{-g_iG-b_iB+a-C}\right|}^{\alpha} \]
Usual choices of \(\alpha\) are 1 and 2 (2 is better as systems that assume smoothness will work better).
I would initially suggest you look at the (non-linear) solvers that ship with Excel and/or Gnumeric.
CB
I'm not so sure it's nonlinear. Consider that you can re-arrange the equation thus:
$$va-r=(v-1)gG+(v-1)bB+(v-1)C=(v-1)(gG+bB+C).$$
Thus, you could try minimizing the difference
$$Ob(G,B,C)=\sum_{i}\left(v_{i}a-r_{i}+(1-v_{i})(g_{i}G+b_{i}B+C)\right)^{2}.$$
You might even be able to derive the explicit formulas you need by using the standard calculus treatment of setting the derivatives
$$\frac{\partial Ob}{\partial G}=\frac{\partial Ob}{\partial B}=\frac{\partial Ob}{\partial C}=0.$$
I'm not sure I said it was intrinsically non-linear, only that it could be solved fairly easily with a non-linear optimisation tool. But in the sense of mathematical programing it is non-linear.
In terms of regression it can be reduced to a linear least squares problem, but are we sure that least squares is the desired optimality condition, also you are not now minimising the sum of square resiuals between the variable of interest and the model. So you have lost any obvious sense in which this is a good fit, that is you have introduced an optimality condition different from minimising the sum some strictly increasing function of the absolute residuals (or some even more general function of the residuals).
If you want to go down this route either you need to prove that the two solutions are the same, or invoke the principle of "good enough for government purposes".
CB
PS I know that I did not leave the optimality condition fully general, but least squares or least absolute value are the two most popular optimality conditions.
PPS Another approach to to treat this a probabilistic problem were the RHS is the probability of v being 1, then we could go down the route of a maximum likelihood (or maximum posterior probability) estimator for the model paramenters - but we would still probably end up with a numerical non-linear least squares problem to solve. See my warship battle-damage survival probability paper for an example of this approach.
FAQ: Solving this system of equations.
How do I know when a system of equations has a solution?
A system of equations has a solution when the equations intersect at a single point. This means that the values of the variables in the equations will satisfy both equations simultaneously.
What is the most efficient method for solving a system of equations?
The most efficient method for solving a system of equations depends on the specific equations and variables involved. However, some commonly used methods include substitution, elimination, and graphing.
Can a system of equations have more than one solution?
Yes, a system of equations can have more than one solution. This occurs when the equations represent parallel lines or when the equations are equivalent and intersect at infinite points.
How can I check my solution for a system of equations?
You can check your solution for a system of equations by plugging the values of the variables into each equation and making sure they satisfy both equations. This is also known as "substitution" and helps to ensure that the solution is correct.
What should I do if a system of equations has no solution?
If a system of equations has no solution, it means that the equations do not intersect and there is no set of values that will satisfy both equations. This could also mean that the equations are inconsistent or that the equations represent parallel lines.
