Solving transcedental equation
  • Thread starter russel.arnold
In summary, to solve the equation tan (f(x)) = g(x) and determine all possible solutions, you will need to consider a particular range and use any numerical method. It is also important to determine the desired level of accuracy, as a graphical approach may not be sufficient. Evaluating f(x) and using its result in the series expansion of tangent can provide accurate solutions for all possible branches.
russel.arnold
41
i want to solve tan (f(x)) = g(x) ..also i want to determine all the possible solutions!
which numerical method i should use?
Mathematics news on Phys.org
There is no one answer.
Since tan has an infinite number of asymptotes, the first questions I'd have to ask is, will you be considering a particular range? Once you have a range, any numerical method could do the job.
I'd also wonder how accurate do you need solutions? To two decimal places? Three? Four? . . . If you didn't need a high degree of accuracy, perhaps even a graphical approach would work for you.
yes, i will be considering tan from 0 to infinity, i.e all possible branches
and i need my solutions to be accurate. hence graphical approach won't work :(
I would first evaluate f(x) and then use that result in the series expansion of tangent taken however far you want to get the accuracy you desire to solve.
That will work for all possible solutions.
There are several numerical methods that can be used to solve transcendental equations, such as the bisection method, the Newton-Raphson method, and the secant method. The best method to use will depend on the specific equation and the initial values given. It is recommended to try different methods and compare the results to determine the most accurate and efficient approach for your specific equation. Additionally, it is important to keep in mind that transcendental equations can have multiple solutions, so it is important to check for all possible solutions when using numerical methods.
FAQ: Solving transcedental equation
What is a transcedental equation?
A transcedental equation is an equation that contains at least one transcendental function, such as trigonometric, exponential, or logarithmic functions.
Why is solving transcedental equations important?
Solving transcedental equations is important in various fields of science and engineering, as many natural phenomena can be described by these equations. It also allows us to find exact solutions for mathematical models and make accurate predictions.
What are some methods for solving transcedental equations?
There are several methods for solving transcedental equations, including graphing, iteration, substitution, and numerical methods such as Newton's method or the bisection method.
What are some common challenges in solving transcedental equations?
Solving transcedental equations can be challenging because they often do not have analytical solutions, meaning they cannot be solved algebraically. This requires the use of numerical methods or approximations to find solutions.
How do I know if I have found the right solution for a transcedental equation?
To ensure that you have found the correct solution for a transcedental equation, you can check it by plugging it back into the original equation and verifying that it satisfies the equation. You can also use a graphing calculator to visualize the equation and its solutions.
10K
