MHB Solving Trig Equations: Help Needed!
  • Thread starter Thread starter Drain Brain
    Trig
The discussion revolves around solving a system of trigonometric equations related to the equilibrium of a particle. The user initially struggles with the equations but successfully derives a quadratic equation for W and finds two potential solutions for W and corresponding angles θ. Both sets of solutions are validated against the original equations, confirming their correctness. However, the choice of which solution to use depends on the specific requirements of the problem, as both solutions are mathematically valid. Ultimately, the user concludes that the preferred solution is W = 240 lb and θ = 40.9°.
Drain Brain
Can you help me how to solve this system of trig eqns
$W\cos(30^{\circ})-275\cos(\theta)=0$
$W\sin(30^{\circ})+275\sin(\theta)=300$
I have tried to divide the first eqn by 2nd and I get
$\tan(30^{\circ})=\frac{275}{300\cos(\theta)}-\tan(\theta)$ I'm stuck here! Kindly help me please!
Mathematics news on Phys.org
Hey Drain Brain!
Suppose we isolate $\cos(\theta)$ and $\sin(\theta)$ in each equation, squared them, and add them.
Then we would be rid of $\theta$ and can solve for $W$.
Afterwards, we can substitute $W$ back in the first equation and solve for $\theta$.
Finally, we should check if the solutions found are actually solutions, since we may have introduced new solutions.
HI I LIKE YOU!:o
I just did what said and came up with a quadratic equation
$W^2-600W\sin(30)+300^2-275^2=0$
the two solutions are
$W=240.1$ and $W=59.86$
$\theta = 40.9$ and $\theta = 79.13$
which of them should I choose?
Drain Brain said:
HI I LIKE YOU!:o
Good! ;)
Actually, you should have 2 solutions for $\theta$ for each value of $W$...
What happens if we substitute them in the second equation?
I like Serena said:
Good! ;)
$240\sin(30^{\circ})+275\sin(40.9)=300$-->>$300=300$ $59.86\sin(30^{\circ})+275\sin(79.13)=300$---->>$300=300$
Does this mean that the values of W and $\theta$ that I get are valid solutions?
Actually the system of equations that I posted above came from a problem about equilibrium of a particle.
I was asked to find force W and angle $\theta$ to satisfy equilibrium conditions. The answer to this problem was 240 lb for W, and $\theta=40.9$. If both sets of solution are valid, why the other solution was not chosen?
Yes, they are both solutions.
It depends on the actual problem statement what to do with them.
Perhaps just a single solution was requested, perhaps there is another reason to discard one of them, or perhaps the given answer is simply incomplete.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
