Solving trigomonetry equation for x
  • Thread starter songoku
So I think it's just a matter of simplifying the equation.In summary, the conversation involves solving a trigonometric equation using a substitution and simplification method. The final equation is not equivalent to the original, but the solution sets are the same. The solution method is not simple and does not involve numerical solutions.
songoku
2,371
349
Solve
[tex]sin^3 x + cos^3 x + \frac{1}{4}(sin x - cos x) = \frac{cos 2x}{cos x - sin x}[/tex]
trigonometry
After putting some effort, I got: sin 4x - sin 2x + 1 = 0
I don't know how to proceed...
Thanks
Set u = sin2x. What's your new equation?
I don't get your hint.
2 sin 2x cos 2x - 2 sin x cos x + 1 = 0
4 sin x cos x (1 - 2 sin2x) - 2 sin x cos x + 1 = 0
4 sin x cos x (1 - 2u) - 2 sin x cos x + 1 = 0
and then...:confused:
Should I change u = sin2x to sin x = √u then draw triangle to find cos x in term of u? I think it will be more complicated
You're thinking into this way too much.
Starting from sin4x - sin2x + 1 = 0, make a simple substitution u = sin2x and plug the u stuff into the equation.
How can you get that equation?
Edit:
My mistake, I thought you meant sin4x, not sin (4x). Ignore my last post!
gb7nash said:
Edit:
So, do you have new idea? :smile:
Or maybe it is not solvable...
You've made a mistake somewhere because the original equation and your final equation aren't equivalent.
[tex](sin x + cos x) (sin^2 x - sin x cos x + cos^2 x) - \frac{1}{4}(cos x - sin x) = \frac{cos 2x}{cos x - sin x}[/tex]
[tex]cos 2x (1 - sin x cos x) - \frac{1}{4}(1 - sin 2x) = cos 2x[/tex]
[tex]4 cos 2x sin x cos x + 1 - sin 2x = 0[/tex]
[tex]sin 4x - sin 2x + 1 = 0[/tex]
Correct?
Sorry, that's my mistake... The expressions aren't equivalent but the solution sets are :biggrin:
minus the [itex]x\neq n\pi+\pi/4[/itex] of course.
It doesn't seem as though this is simple to solve. Were you expecting a numerical solution?
I don't think so; we haven't covered numerical solution.
FAQ: Solving trigomonetry equation for x
What is a trigonometry equation?
A trigonometry equation is an equation that involves trigonometric functions, such as sine, cosine, and tangent, and an unknown variable x. The goal of solving a trigonometry equation is to find the value of x that makes the equation true.
How do I solve a trigonometry equation for x?
To solve a trigonometry equation for x, you need to use trigonometric identities, such as the Pythagorean identity or the double angle identity, to manipulate the equation and isolate x on one side. You can also use the inverse trigonometric functions to solve for x.
What are the common mistakes when solving trigonometry equations for x?
Common mistakes when solving trigonometry equations for x include forgetting to use the correct trigonometric identity, making calculation errors, and forgetting to check for extraneous solutions. It is important to carefully follow the steps and double check your work when solving these equations.
Can I use a calculator to solve a trigonometry equation for x?
Yes, you can use a calculator to solve a trigonometry equation for x. However, it is important to note that calculators may not always give exact solutions and may round the values. It is always a good idea to check your solution by plugging it back into the original equation.
Why is it important to learn how to solve trigonometry equations for x?
Trigonometry equations are important in many fields of science, such as physics, engineering, and astronomy. Being able to solve these equations for x allows you to find missing information, make predictions, and solve real-world problems. It also helps develop critical thinking and problem-solving skills.
