songoku
- 2,365
- 347
1. A ball is tied to a string then moved so that its trajectory is vertical circle. If the mass of the ball is 500 g, the speed is 2 m/s, and the length of string is 50 cm, find the tension when it is at the top of the trajectory
2. A mass m is tied to a string and moved so that its trajectory is vertical circle. The maximum and minimum value of the tension are 90 N and 10 N respectively. Determine the mass and linear speed of the mass
F = mv2/r
W = mg
1. T = mv2/r - mg = 4 - 5 = -1 N ?
It is possible that at the top of its motion, the tension becomes loose and yet it still moves in circle? If not, where is my mistake?
2. maximum when it is at bottom and minimum when it is at top
at bottom: 90 = mg + mv2/r
at top: 10 = mv2/r - mg
By elimination, I got m = 4 kg but I can't find v. Any suggestions?
Thanks
