Solving x^{101}+x^{83}+x=1 with Rolle's Theorem
  • MHB
  • Thread starter Yankel
  • Tags
    Theorem
In summary, Rolle's theorem tells you that if you have a continuous and differentiated function on a closed interval [a,b], then there exists a point c within that interval such that f'(c) = 0.
Yankel
395
Hello, I need to find the solutions of this equation using Rolle's theorem
(the one saying that if f is a continuous and differentiated function on [a,b] then there exist a point c (a<c<b) such that f'(c)=0 )[tex]x^{101}+x^{83}+x=1[/tex]
Thanks...
Thanks...
You have left out a crucial condition of Rolle's theorem, namely the requirement that $f(a) = f(b)$.
Let $f(x) = x^{101}+x^{83}+x - 1$. Then $f'(x) = 101x^{100} + 83x^{82} + 1$, which is always positive, never zero. Rolle's theorem tells you that the equation $f(x)=0$ can have at most one solution. (If there were two points where $f(x)=0$ then Rolle's theorem would tell you that $f'(x)=0$ at some intermediate point.)
Can you see why the equation $f(x)=0$ must have one solution, and can you narrow down the interval in which that solution occurs? (You will not be able to find an exact solution, using Rolle's theorem or any other method.)
yes, I can see it now, thank you !
FAQ: Solving x^{101}+x^{83}+x=1 with Rolle's Theorem
What is Rolle's Theorem?
Rolle's Theorem is a mathematical theorem that states that if a function is continuous on a closed interval and differentiable on an open interval within that closed interval, and the values of the function at both endpoints of the interval are equal, then there exists at least one point within the interval where the derivative of the function is equal to zero.
How does Rolle's Theorem help in solving equations?
Rolle's Theorem can help in solving equations by providing a way to prove the existence of a solution within a certain interval. In the case of x^{101}+x^{83}+x=1, Rolle's Theorem can be used to show that there exists at least one point where the derivative of the function is equal to zero, which can help in finding the solution.
Can Rolle's Theorem be used to find all solutions to an equation?
No, Rolle's Theorem can only provide information about the existence of a solution within a certain interval. It cannot be used to find all solutions to an equation.
What is the significance of the given equation x^{101}+x^{83}+x=1?
The given equation is an example of a polynomial equation that can be solved using Rolle's Theorem. It is significant because it demonstrates the application of Rolle's Theorem in finding solutions to polynomial equations.
Can Rolle's Theorem be applied to all types of functions?
No, Rolle's Theorem can only be applied to continuous functions that are differentiable on an open interval. It cannot be applied to discontinuous or non-differentiable functions.
