Solving x^2 + 2y = 9 w/ Sub Method
In summary, the conversation discussed using the substitution method to solve the equations x^2 + 2y = 9 and x - y + 3 = 0. By substituting y with x+3, the equations were simplified and factored to find the values of x, which were then substituted back into the original equations to solve for y. The solutions were found to be (x,y) = (-3,0) and (x,y) = (1,4).
wat2000
46
use the subtitution method to solve.
x^2 + 2y = 9
x - y + 3 = 0
y=x+3 -> (3)
substitute for y with x+3, you get:
x^2+2(x+3)=9 x2+2x−3=0
factorize it to get:
(x+3)(x−1)=0 x=−3,x=1
substitute for each value of x in equation 3
x=−3y=−3+3=0
x=1y=1+3=4
(x,y)=(−3,0),(x,y)=(1,4)
Is this right?
x^2 + 2y = 9
x - y + 3 = 0
y=x+3 -> (3)
x=−3y=−3+3=0
x=1y=1+3=4
Is this right?
You can check for yourself. Do you get true statements for the two equations when x=-3, y = 0 and when x = 1, y = 4?
So its right!
Related to Solving x^2 + 2y = 9 w/ Sub Method
1. What is the "Sub Method" in solving x^2 + 2y = 9?
The "Sub Method" in solving x^2 + 2y = 9 is a mathematical technique used to isolate a variable in an equation by substituting one variable with another expression.
2. How do you use the "Sub Method" to solve x^2 + 2y = 9?
To use the "Sub Method" in solving x^2 + 2y = 9, you first isolate one of the variables, either x or y. Then, you substitute the expression for the isolated variable into the equation and solve for the remaining variable.
3. What are the benefits of using the "Sub Method" to solve equations?
The "Sub Method" is a useful tool for solving equations because it allows you to isolate and solve for one variable at a time, making the process more systematic and easier to follow. It also helps to avoid confusion and mistakes when solving complex equations.
4. Are there any limitations to using the "Sub Method" in solving equations?
The "Sub Method" may not be the most efficient method for solving certain equations, especially those with multiple variables and exponents. It also requires careful attention to detail and may be more time-consuming compared to other methods.
5. Can the "Sub Method" be applied to other types of equations?
Yes, the "Sub Method" can be applied to various types of equations, including linear, quadratic, and exponential equations. It is a versatile technique that can be used in many different mathematical problems.
