Solving $x,y,z$: Equations (1), (2), (3)
  • MHB
  • Thread starter Albert1
In summary, the conversation discusses finding solutions for $x, y, z$ in three equations. By simplifying and using substitution, the solutions that were found are $x = \frac{23}{10}, y = \frac{23}{6}, z = \frac{23}{2}$.
Albert1
1,221
find solutions of $x,y,z$
$\dfrac {1}{x}+\dfrac {1}{y+z}=\dfrac {1}{2}-----(1)$
$\dfrac {1}{y}+\dfrac {1}{z+x}=\dfrac {1}{3}-----(2)$
$\dfrac {1}{z}+\dfrac {1}{x+y}=\dfrac {1}{4}-----(3)$
Mathematics news on Phys.org
Hello, Albert!
I have a very looong solution.
Find solutions of $x,y,z$
.[tex]\begin{array}{cccc}\frac {1}{x}+\frac {1}{y+z} &=& \frac {1}{2} & [1[ \\
\frac {1}{y}+\frac {1}{z+x}&=&\frac {1}{3} & [2] \\
\frac {1}{z}+\frac {1}{x+y}&=&\frac {1}{4} & (3) \end{array}[/tex]
Note that: .[tex]x,y,z\, \ne\,0.[/tex]
[tex]\begin{array}{cccccccccc}[1]\!:\;2y + 2x + 2x \:=\:x(y+z) &\Rightarrow& x + y + z \:=\: \frac{xy+xz}{2} & [4] \\
[2]\!:\; 3x + 3x + 3y \:=\:y(x+z) &\Rightarrow & x+y+z \:=\:\frac{xy+yz}{3} & [5] \\
[3]\!:\; 4x+3y+4z \:=\:z(x+y) & \Rightarrow & x+y+z \:=\:\frac{xz+yz}{4} & [6] \end{array}[/tex]
[tex]\text{From }[4],[5],[6]\!:\;\underbrace{\frac{xy+xz}{2}}_{[7]} \:=\:\underbrace{\frac{xy + yz}{3}}_{[8]} \:=\:\underbrace{\frac{xz+yz}{4}}_{[9]}[/tex]
[tex][7]=[8]\!:\;3xy + 3xz \:=\:2xy + 2yz \;\;\;\Rightarrow\;\;\; x \:=\:\frac{2yz}{y+3x}\;\;[10][/tex]
[tex][8] = [9]\!:\;4xy + 4yz \:=\:3xz + 3yz \;\;\;\Rightarrow\;\;\;x \:=\:\frac{yz}{3x-4y}\;\;[11][/tex]
[tex][10]=[11]\!:\;\frac{2yz}{y+3x} \:=\:\frac{yz}{3z-4y} \quad\Rightarrow\quad z \:=\:3y\;\;[12][/tex]
Substitute into [10]: .[tex]x \:=\:\frac{2y(3y)}{y+3(3y)} \quad\Rightarrow\quad x \:=\:\tfrac{3}{5}y\;\;[13][/tex]
Substitute [12] and [13] into [4]:
.. [tex]2y + 2(3y) + 2\left(\tfrac{3}{5}y\right) \;=\; \left(\tfrac{3}{5}y\right)y + \left(\tfrac{3}{5}y\right)(3y) [/tex]
. . [tex]\tfrac{46}{5}y \:=\:\tfrac{12}{5}y^2 \quad\Rightarrow\quad 6y^2\:=\:23y \quad\Rightarrow\quad \boxed{y \:=\:\tfrac{23}{6}}[/tex]
Substitute onto [13}: .[tex]x \:=\:\tfrac{3}{5}\left(\tfrac{23}{6}\right) \quad\Rightarrow\quad \boxed{x \:=\:\frac{23}{10}}[/tex]
Substitute into [12]: .[tex]z \:=\:3\left(\tfrac{23}{6}\right) \quad\Rightarrow\quad \boxed{z \:=\:\frac{23}{2}}[/tex]
http://www.mymathforum.com/viewtopic.php?t=36640&p=151646
Nicely done!
very good solution there :)
I would first analyze the equations and their relationships to each other. It is clear that these equations form a system of linear equations, with three unknown variables: x, y, and z. In order to solve for these variables, we would need to use methods such as elimination or substitution.
However, before proceeding with solving the equations, we should check for any inconsistencies or contradictions within the system. This can be done by rearranging the equations and looking for any patterns or relationships between them. For example, in this system, we can see that the denominators of each equation are all related to the variables in the other equations. This suggests that there may be a unique solution to this system of equations.
Next, we can use algebraic methods such as elimination or substitution to solve for the variables. By rearranging the equations and substituting one into the other, we can eventually solve for each variable. It is important to note that there may be multiple solutions to this system of equations, so we should check our answers and make sure they satisfy all three equations.
In conclusion, as a scientist, I would carefully analyze the system of equations and use appropriate methods to solve for the variables. I would also check for any inconsistencies or contradictions and make sure to verify my solutions. By doing so, we can confidently find the solutions for x, y, and z.
FAQ: Solving $x,y,z$: Equations (1), (2), (3)
What are the 3 equations used to solve for x,y,z?
The 3 equations used to solve for x,y,z are typically referred to as simultaneous equations. They can be written in the following form:
Equation (1): ax + by + cz = d
Equation (2): ex + fy + gz = h
Equation (3): ix + jy + kz = l
Where a,b,c,e,f,g,i,j,k are coefficients and d,h,l are constants.
What is the process for solving simultaneous equations?
The process for solving simultaneous equations involves finding the values of x,y,z that satisfy all 3 equations. This can be done through various methods such as substitution, elimination, or using matrices. The goal is to manipulate the equations to get a single equation with one variable, which can then be solved to find its value. This value can then be substituted back into the other equations to find the values of the remaining variables.
What are the common challenges when solving simultaneous equations?
One common challenge when solving simultaneous equations is identifying which method would be the most efficient to use. Another challenge is making sure all the equations are in the same form (either standard form or slope-intercept form) to be able to manipulate them easily. It is also important to be careful with calculations and keep track of the steps to avoid making errors.
What are some strategies for solving simultaneous equations?
Some strategies for solving simultaneous equations include graphing the equations to get an estimate of the solution, setting one variable equal to an expression in terms of the other variables and substituting it into the other equations, or using matrices and Gaussian elimination to create an augmented matrix and solve for the variables.
How can simultaneous equations be used in real-life situations?
Simultaneous equations can be used in various real-life situations, such as finding the number of items that need to be sold to break even in a business, determining the optimal amount of ingredients to use in a recipe, or calculating the intersection point of two moving objects. They can also be used in physics and engineering to solve for multiple unknowns in a system of equations.
