Solving xu_t + uu_x = 0: Need Help with Change of Variables
In summary, the problem was that the author was not sure how to use the change of variables hint, and the solution was found without using it.
ryo0071
Okay so I am working on this problem:
Solve \(\displaystyle xu_t + uu_x = 0\) with \(\displaystyle u(x, 0) = x.\)(Hint: Change variables \(\displaystyle x \rightarrow x^2\).)
However, I am not sure how to use the change of variables hint that is given or why it is needed. My thinking is that I could just use the method of characteristic as normal to get the solution. Any help is appreciated.
Yes, I'm not sure why the hint is even suggested unless maybe you solved
$u_t + u u _x = 0,\;\; u(x,0)=f(x)$.
already. The method of characteristic will work fine. Are you familiar with this method?
The general solving procedure of a nonlinear PDE of the type... $\displaystyle u_{t} + \varphi(u,x)\ u_{x} = f(x,t),\ u(x,0)= g(x)\ (1)$
... is the following. First we write the system of three ODE...
$\displaystyle \frac{d t}{d s}=1,\ t(0)=0$
$\displaystyle \frac{d x}{d s}= \varphi(u,s),\ x(0)= \xi$
$\displaystyle \frac{d v}{d s} = f(x,t),\ v(0)=g(\xi)\ (2)$... then we solve (2) obtaining $\displaystyle t=t(s, \xi),\ x=x(s,\xi), v=v(s, \xi)$ and then $\displaystyle s=s(x,\ t), \xi=\xi(x,\ t)$. The solution of (1) is...
$\displaystyle u(x,\ t) = v \{s(x,\ t),\ \xi(x,\ t)\}\ (3)$
In Your case is $\displaystyle \varphi (u,\ x) = \frac{u}{x},\ f(x,t) = 0,\ g(x)=x$ so that the (2) becomes...
$\displaystyle \frac{d x}{d s}= \frac{v}{s},\ x(0)= \xi$
$\displaystyle \frac{d v}{d s} = 0,\ v(0)=\xi\ (4)$
With a little of patience You solve (4) obtaining...
$\displaystyle t=s$
$\displaystyle v=\xi$
$\displaystyle x=\sqrt{2 s \xi + \xi^{2}}\ (5)$
If You invert (5) obtain...
$\displaystyle s=t$
$\displaystyle \xi = -t + \sqrt{t^{2} + x^{2}}\ (6)$
... and (6) permits You to write...
$\displaystyle u(x,\ t)= -t + \sqrt{t^{2} + x^{2}}\ (7)$
Kind regards
$\chi$ $\sigma$
Thank you both for the help. I was trying to use the hint but what was confusing me was that they used the same variable x for both parts of the change of coordinates (rather than doing something like \(\displaystyle x \rightarrow \eta^2\)). Anyway, I was able to solve it by method of characteristics without using the coordinate transform. Again, thank you both for the assistance.
Hello,
Thank you for reaching out for help with this problem. Change of variables can be a useful tool in solving differential equations, especially when the equation is nonlinear like the one you are working on.
In this case, the change of variables is suggested as x → x^2. This means that instead of using x as your independent variable, you will use x^2. This can be helpful because it can transform the equation into a simpler form that is easier to solve.
To use this method, you will need to make the following substitutions:
u = u(x^2, t) and x = x^2
Then, you can calculate the partial derivatives of u with respect to x and t, and substitute them into the original equation. This will give you a new equation in terms of u, x^2, and t.
From there, you can use the method of characteristics to solve the new equation and find the solution for u.
I hope this helps. If you have further questions or need more clarification, please don't hesitate to ask. Best of luck with your problem!
FAQ: Solving xu_t + uu_x = 0: Need Help with Change of Variables
1. What does the equation xu_t + uu_x = 0 represent?
This equation is a nonlinear partial differential equation known as the inviscid Burgers' equation, which is used to model the conservation of mass and momentum in fluid flow.
2. How can I solve this equation using change of variables?
The most common approach is to use the Cole-Hopf transformation, which transforms the Burgers' equation into a linear heat equation. This can then be solved using standard methods.
3. What are some examples of problems that can be modeled using this equation?
The Burgers' equation has many applications in fluid dynamics, including modeling shock waves, turbulence, and boundary layer flows. It can also be used in other fields, such as traffic flow and financial modeling.
4. Are there any limitations or assumptions when using this equation?
One limitation is that it assumes the fluid is inviscid, meaning that there is no friction or viscosity. It also assumes that the flow is one-dimensional and that the fluid properties do not change with time.
5. How does solving this equation contribute to scientific research?
Solving the inviscid Burgers' equation can provide insights into the behavior of fluid flow and other systems that can be modeled using this equation. It can also lead to the development of new analytical and numerical methods for solving similar equations and advance our understanding of complex phenomena in various scientific fields.
