Some algebra I don't understand: Solve for R
  • Thread starter Thread starter Jaccobtw
    Algebra Algebra i
To solve for R in the equation 5/3 = (0.28 + R)/R, the variable R is not isolated as it appears in both the numerator and denominator. A recommended approach is to eliminate the fractions by multiplying both sides by R and then isolating terms with R. Another method involves multiplying both sides by 3R to simplify the equation further. Simplifying the right side can help reduce the complexity of the equation, making it easier to solve for R. Ultimately, the goal is to isolate R to find its value.
Jaccobtw
Solve for R. $$\frac{5}{3} = \frac{0.28 + R}{R}$$
Use algebra I guess
The variable is already isolated on one side. I dont' know how to solve for R though. Any help? Thank you.
Jaccobtw said:
Homework Statement:: Solve for R. $$\frac{5}{3} = \frac{0.28 + R}{R}$$
Relevant Equations:: Use algebra I guess
Fractions are always a problem. Get rid of them!
Likes FactChecker and Jaccobtw
Ah ok. Multiply both sides by R and then subtract R from both sides. The rest is cake
Likes berkeman, FactChecker, PhDeezNutz and 1 other person
Better yet, multiply both sides of the equation by 3R, and then isolate the terms with R on one side.
the difficulty here is R appears twice
we can either merge the R's or eliminate one
to do the later we can...
subtract one from both sides
$$\frac{5}{3} -\frac{3}{3}= \frac{0.28 + R}{R}-\frac{R}{R}$$
Although R is only on the right-side, I would not describe that R as "isolated".
While true, it may be better to simplify [to reduce the number of R's one sees on]
the right-hand-side by first distributing the [common] denominator, then simplifying further
$$\begin{align*}\frac{5}{3}
\frac{0.28 + R}{R}\\
\frac{0.28}{R} + 1\\
\end{align*}
