MHB Some basic questions on Graph theory
The discussion centers on basic questions in graph theory, particularly focusing on properties of graphs based on their degree and structure. The first question addresses proving that a graph with a maximum degree of 2 consists of paths and cycles, with a suggested proof using induction. The second question involves demonstrating that a graph exceeding a specific size contains cycles of length 3 or 4, which is noted as a challenging problem. The third question seeks the number of non-isomorphic graphs of a given order, while the fourth question raises confusion regarding the term "weighted" in relation to bipartite sub-graphs. Lastly, the fifth question confirms that a connected graph will have at least two vertices that are not cut vertices, using properties of spanning trees.
Mathelogician
Hello everybody!
I am a real amateur in Combinatorics. So please answer in the most basic way!
1- Suppose for a graph G we have Delta=max(deg Vi : 1<=i<=n).
If Delta<=2, prove that the graph G is made up of Paths and Cycles.
2- Suppose G is a graph of size m > (n*sqrt(n-1))/2. Prove that G has a Cycle with length of 3 or 4.
3- How many graphs of order n do exists that are not isomorphic?
4- For an arbitrary graph G show that there exists a weighted bipartite sub-graph H such that:
for all v in V(G), deg H (v)>= (deg G (v))/2.
5- Suppose that G is a graph of size m>=1. Show that G has at least 2 vertices that are not cut vertex.
Regards.
Mathelogician said:
Hello everybody!
Regards.
Hello Mathelogician.
I can help you on a few of these.
For the first one induction on the order of $G$ can be used. There are two cases.
Case 1: There exists a cycle, say $C$, in $G$. Show that $C$ is actually a component. Delete $C$ to form $H=G-C$. Note that $H$ again satisfies $\Delta(H)\leq 2$ and has order strictly less that order of $G$. Induction sets in. Don't forget to show the base case.
Case 2: There are no cycles in $G$. Then Take any maximal path $P$ in $G$ and show that this is a component of $G$. Rest is same as in case 1.
For the third one see How many different possible simply graphs are there with vertex set V of n elements - MathOverflow
I don't understand the fourth question. Why is the term 'weighted' appearing in there?
For the fifth of course we assume that the graph is connected. So it has a spanning tree say $T$. Every tree has at least two leaf nodes. Choose any two leaf nodes in $T$. Deleting these doesn't disconnect $G$. (why?)
I will get back on the second one in some time.
P.S. Read the forum rules. I don't think one is allowed to post more than two questions in one post. Also, you are required to show your attempt when you post the questions. One more thing, try posting using LaTeX. You can read the LaTeX forum on the homepage for help on this.
Mathelogician said:
Hello everybody!
Regards.
The second question is very hard. See https://docs.google.com/viewer?a=v&...qG6Lz7&sig=AHIEtbTPDEPPZXjMJHOtdiFvCZU4CNmUfA
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
