Some basics of power loss and voltage drop in cables
In summary, it is possible to calculate the power loss in cables using the formula power loss = I^2 * R. For voltage drop, it is important to know the resistance of the cable and the current through it in order to calculate the voltage drop through the cable. Adding the resistance of the load and the resistance of the wire in series will decrease the current and voltage received by the load. It is recommended to use a thicker cable for longer distances or higher currents to avoid significant voltage drop.
tommy060289
Hey everyone, I could do with a hand checking my understanding of calculating the current loss in cables just to make sure I am doing it right.
First up, is power loss. From my understanding of ohms law and P=VI it is possible to calculate the power loss in cables by using the formula power loss = I^2 * R
So if for example I had a 10W bulb, does this mean my total power draw would be 10W + loss? Is that correct.
Next voltage drop. I found a table which gives me a voltge drop for different cable at different voltages, etc and a 0.75mm^2 two core cable running 12V has a loss of 0.058V/A/m which means on a 3 Amp current that spans 20 m Id have a voltage drop of 0.058*3*40 of almost 7V. Doesnt this sound like a lot. Have I worked something out wrong. I know DC loses out of distance but this still seems like a lot? Obviously the solution is to use thicker cable but I just want to make sure my understanding is correct before going any further. For the record 0.75mm^2 is good for 6 Amp so its not like the cable is unsuitable for the ampage. From my understanding, it would be pretty typical for voltage drop to be no more than 10%
Thanks for your help
I have checked your numbers and they seem OK.
The resistivity of copper is 1.7*10^-8 Ωm so a copper cable with cross sectional area
0.75mm^2 would have a resistance of 0.022Ω/m. I don't know where your figure of
0.058Ω/m comes from but the 2 numbers are of the same 'order of magnitude'
hope this helps
This isn't entirely true..
A 12 V 10 watt bulb only dissipates 10 watts if it gets 12 volts.
All you can say is that at 12 volts it has a resistance of 14.4 ohms. { 12 * 12 / 14.4 (E2/ R) = 10 watts }
So, if there are losses in the power line or if it gets some other voltage, then you can estimate the power dissipated in the lamp, but you can't calculate it exactly because the resistance of the lamp depends on the temperature of the filament.
Here's an example to get you thinking.
Say you have 20 or so lights on a single circuit that draw roughly 10 amps. You would think that a #12 gauge wire would work fine. It does up to a couple hundred feet.
But let's say you have to go 500 ft or so...like in the case of outdoor parking lights in a parking lot or something like that. Let's say you are using single phase 277 volts.
The 12 gauge works fine at 200 ft...however...at 500 ft there is too much of a voltage drop and you lights will not operate correctly. If you use a voltage drop chart or do the math yourself...you will see that you need a #8 gauge wire to keep the voltage drop with the proper parameters.
U can use V=IR (multiply resistance of wire times current)...or P=I^2*R...or P=IV...all will get you there...but V=IR seems easiest in my opinion.
so are you saying I should use V = IR to calculate voltage drop or current loss?
surely it wouldn't work for voltage drop as when current is dropped and voltage is increased, the voltage drop reduces.
Im not entirely sure what to do with my current losses though as here is the set up.
I have a 12V battery rigged to 6x 6 Watt light bulbs 20 m away. The bulbs are 12V so the current is 3A.
if I factor in the cable losses for current though wouldn't the current draw be higher than 3A due to the cable losses or would the current just be less than 3A at the light?
The voltage drop I am reffering to is in the cable...not the load. U need to know the resistance of your cable...an ohmeter will work...or specs. If you know the current through the cable...simply multiply by the resitance...and u will now have the voltage drop thru the cable. Or sometimes the specs of the cable will give you ohms per feet of whatever.
Actually...you are going to lower the current...simply because you have added the resistance of the load and the resistance of the wire in series. You now have a TOTAL greater resistance. V=IR. In this situation...you have actually lowered the current (because V stayed the same and R went up) if you look at the math. So your light will be getting less than 3 amps...and also be getting less than 12 volts. It should still work fine...just maybe be a hair more dim.
There's no way you drop 7 volts if your cable can handle 6 amps. If you have a 10 watt load and a 12 volt battery...you are looking at less than an amp.
I'm not sure what V/A/m means?
Using the handy excel chart I have...1 amp at 20 meters for 12 volt DC has a voltage drop of .8 volts guessing an 18 gauge wire. Maybe a hair high...compared to 12 volts...but not horrible. Maybe consider using a 14 gauge wire...only .3 voltage drop and roughly 2% voltage drop which is acceptable.
Incidentally...I'm not totally sure about what I'm saying here...just throwing some things around.
V/A/m I would say means Ω/m because V/A = resistance.
That is why I looked up resistivity to calculate the resistance of the cables being talked about.
Copper wire of cross sectional area 0.75mm^2 has a resistance of 0.022Ω/m so 20m of wire has a resistance of 0.45Ω
oK...SO .058 * 20 METERS = 1.16 ohms.
10 watt bulb...P=IV...10w=I*12...current is .83 amps with perfect wire thru lamp.
(V^2)/R=P...(12^2)/R=10...or R=14.4 ohms in light. Add in the 1.16 ohms for wire...total load is 15.56 ohms
V=IR 12=I*15.56...I=.77 amps.
P=IV P=.77* 12 Power to lamp is 9.24 watts...slightly dimmer.
.76 watts was lost in wire.
Do a voltage divider of resistors in series...one resistor of 1.16 (wire) and other resistor is 14.4 ohms (light)
12 volts X (1.16/(1.16 +14.4)) = .89 voltage drop in wire. This agrees with the ~.8 volts I mentioned from the chart above.
Makes sense...I think. With your wire size...your lamp will have 92% of its brightness.
Related to Some basics of power loss and voltage drop in cables
1. What is power loss in cables?
Power loss in cables refers to the amount of energy that is dissipated as heat when electricity is transmitted through a cable. This loss is caused by the resistance of the cable, which results in a drop in voltage and a decrease in the amount of power that reaches the end of the cable.
2. What factors contribute to power loss in cables?
The main factors that contribute to power loss in cables are the length of the cable, the material and size of the conductors, and the frequency and magnitude of the current flowing through the cable. Other factors such as ambient temperature and the type of insulation can also affect power loss.
3. How is power loss calculated in cables?
Power loss in cables can be calculated using Ohm's Law, which states that power loss (P) is equal to the square of the current (I) multiplied by the resistance (R) of the cable. Additionally, the power loss can also be calculated by measuring the voltage drop across the cable using a voltmeter.
4. What is voltage drop in cables?
Voltage drop in cables is the decrease in voltage that occurs when electricity is transmitted through a cable. This is caused by the resistance of the cable, which results in a loss of energy and a decrease in the voltage that reaches the end of the cable. Voltage drop can cause problems in electrical systems, such as decreased efficiency and potential damage to equipment.
5. How can power loss and voltage drop in cables be minimized?
To minimize power loss and voltage drop in cables, it is important to use the correct size and type of cable for the specific application. This will help reduce the resistance of the cable and therefore decrease the amount of power loss. Additionally, keeping cable lengths as short as possible and using proper insulation can also help minimize power loss and voltage drop.
  • Electrical Engineering
9K
