MHB Some considerations about conditional normal distribution....
The discussion centers on whether the conditional distribution P(X|Y) is normal when P(X), P(Y), and P(Y|X) are all normal, given that X and Y are dependent random variables. Initial assertions suggest that P(X|Y) must also be normal, but this claim faces skepticism from other members who seek a formal proof. The conversation highlights the symmetry in the definitions of conditional distributions and emphasizes the need to derive explicit expressions for the joint and conditional densities. An important point raised is that normal marginals do not guarantee joint normality, and proving the relationship requires justifying the independence of variance in the conditional distribution. The thread aims to clarify these complexities surrounding conditional normal distributions.
chisigma
MHB
Scope of this thread is to give a complete as possible answer to the question proposed two days ago by the user simon11 on Basic Probability and Statistic forum...
Assume two random variables X and Y are not independent, if P(X), P(Y) and P(Y|X) are all normal, then does P(X|Y) also can only be normal or not necessarily?...
My 'almost automatic' answer has been 'yes!... P(X|Y) must necessarly be a normal distribution too...', but other members of MHB expressed critics or doubts about that, so I intend to clarify all the aspects not enough clear of the problem. The first step to perform the task is to remember the definition of conditional distribution function. According to...
Conditional probability distribution - Wikipedia, the free encyclopedia
... if the r.v. X has p.d.f. $f_{X} (x)$, the r.v. Y has p.d.f. $f_{Y}(y)$, and X and Y have joint density function $f_{X,Y} (x.y)$, then the conditional probability distribution functions of X and Y, one conditioned by the other, are...
$\displaystyle f_{Y} (y|X=x) = f_{Y|X} (x,y) = \frac{f_{X,Y} (x,y)}{f_{X}(x)}$ (1)
$\displaystyle f_{X} (x|Y=y) = f_{X|Y} (x,y) = \frac{f_{X,Y} (x,y)}{f_{Y}(y)}$ (2)
Very well!... now the basic definitions (1) and (2) give the answer to the question of simon11... why?... observing (1) and (2) it is fully evident their intrinsic symmetry respect to the X and Y, so that is always possible to swap the roles of X and Y and if $f_{X}$,$f_{Y}$ and $f_{Y|X}$ have the same property, no matter which is the property, also $f_{X|Y}$ has that property. After some marginal clarifications, simon11 seems to have been satisfied by the answer. One member of the staff of MHB however wasn’t and required a ‘formal proof’. Well!... in order to do that the first step is to find, under the assumption that X and Y are normal r.v., the explicit expressions of $f_{X}$,$f_{Y}$ and $f_{X,Y}$ and use (1) and (2) to obtain $f_{X|Y}$ and $f_{Y|X}$. No matter of course for the first two...
$\displaystyle f_{X}(x)= \frac{1}{\sqrt{2\ \pi}\ \sigma_{X}}\ e^{- \frac{(x-\mu_{X})^{2}}{2\ \sigma^{2}_{X}}}$ (3)
$\displaystyle f_{Y}(y)= \frac{1}{\sqrt{2\ \pi}\ \sigma_{Y}}\ e^{- \frac{(y-\mu_{Y})^{2}}{2\ \sigma^{2}_{Y}}}$ (4)
... but how to say about $f_{X,Y}$?... 'Monster Wolfram' helps us...
Bivariate Normal Distribution -- from Wolfram MathWorld
$\displaystyle f_{X,Y} (x,y)= \frac{1}{2\ \pi\ \sigma_{X}\ \sigma_{Y}\ \sqrt{1-\rho^{2}}}\ e^{- \frac{z}{2\ (1-\rho^{2})}}$ (5)
... where...
$\displaystyle z= \frac{(x-\mu_{X})^{2}}{\sigma^{2}_{X}} - 2\ \frac{\rho\ (x-\mu_{X})\ (y-\mu_{Y})}{\sigma_{X}\ \sigma_{Y}} + \frac{(y-\mu_{Y})^{2}}{\sigma^{2}_{Y}}$ (6)
$\displaystyle \rho= \text{cor}\ (X,Y)= \frac{V_{X,Y}}{\sigma_{X}\ \sigma_{Y}}$ (7)
Usually $\rho$ is called 'correlation' of X and Y and $V_{X,Y}$ is called 'covariance' of X and Y. The (6) and (7) are very interesting and 'suggestive' because the presence of the term $\rho$. In X and Y independent [or more precisely unrelated...], then $\rho=0$, if not [and that is the case proposed by simon11...] an 'extra term' must be taken into account. Now we are able, using (1) and (2), to compute $f_{Y|X} (x,y)$ and $f_{X|Y} (x,y)$ with a symple division...
$\displaystyle f_{Y|X} (x,y)= \frac{1}{\sqrt{2\ \pi}\ \sigma_{Y}\ \sqrt{1-\rho^{2}}}\ e^{- \frac{u}{2\ (1-\rho^{2})}}$ (8)
... where...
$\displaystyle u= \frac{(y-\mu_{Y})^{2}}{\sigma^{2}_{Y}} -2\ \rho\ \frac{(y-\mu_{Y})\ (x-\mu_{X})}{\sigma_{Y}\ \sigma_{X}} + \rho^{2}\ \frac{(x-\mu_{X})^{2}}{\sigma^{2}_{X}}$ (9)
$\displaystyle f_{X|Y} (x,y)= \frac{1}{\sqrt{2\ \pi}\ \sigma_{X}\ \sqrt{1-\rho^{2}}}\ e^{- \frac{v}{2\ (1-\rho^{2})}}$ (10)
... where...
$\displaystyle v= \frac{(x-\mu_{X})^{2}}{\sigma^{2}_{X}} -2\ \rho\ \frac{(x-\mu_{X})\ (y-\mu_{Y})}{\sigma_{X}\ \sigma_{Y}} + \rho^{2}\ \frac{(y-\mu_{Y})^{2}}{\sigma^{2}_{Y}}$ (11)
So 'finally' we are arrived to an explicit expression for $f_{Y|X}$ and $f_{X|Y}$ in the general case where X and Y are not independent. A I said before $f_{Y|X}$ is obtained from $f_{X|Y}$ swapping the role of X and Y... of course!... now by integration one can compute, if desired, $\mu_{Y|X}$, $\mu_{X|Y}$,$\sigma^{2}_{Y|X}$, $\sigma^{2}_{X|Y}$ and other interesting parameters... now I'm a little tired and that will be made, in case, in a successive post... Kind regards $\chi$ $\sigma$
... where...
... where...
... where...
You seem to be assuming that normal marginals implies joint normality. This is false.
If you could prove that both marginals normal plus one conditional normal implies that the joint distribution is normal you would be done. But this requires that the variance of the conditional be independent of the conditioning value, which we would have to justify.CB
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
