I Some doubts about determining experiments
The discussion revolves around determining the correct experimental approach to check the homogeneity of space when dropping a ball. Two methods are proposed: moving slightly while dropping the ball from the same height or remaining stationary but dropping it from a greater height. The first method is argued to maintain consistent initial conditions, while the second method raises questions about the validity of the Lagrangian approach in assessing homogeneity. The Lagrangian formulation suggests that shifting the drop height could still be valid, leading to confusion about which experimental method is correct. Ultimately, the conversation concludes that both methods can be valid under different interpretations of spatial homogeneity.
gionole
Imagine experiment is such as I drop a ball from some height vertically only.
What’s the right way to do 2nd experiment in order to check homogeneity of space.
Way 1: I move a little bit and drop the ball (same height, it’s just I moved - ball as well, but not in terms of height)
Way 2: We stay at the same place, but we drop the ball from higher height.I remember there was a constant speed moving train example and we were checking homogeneity such as we were in the train frame, drop, then we moved further in the train and drop it again from the same height. If so, then way 1 must be correct(since the experiments must be done with the same initial conditions - initial location, initial speed).
What I don’t get now is Lagrangian case for which we do for homogeneity check. For the ball, we know Lagrangian would be: ##L(y) = \frac{1}{2} mv^2 - mgy##
Then we say ##L(y+a) = \frac{1}{2} mv^2 - mg(y+a)##
How is this valid ? We definitely shift the ball upper, while we said that way 1 was correct above. Does this mean Way 2 is correct ?
We check
Way 2:homogeneity in space y
Way 1: homogeneity in space z or x.
Likes gionole
All good. No need for further replies. Thanks.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
