Some Explanation with Rigid Rotator
  • Thread starter firoz.raj
  • Tags
    Explanation
In summary, the Rigid Rotator is a type of rotor that has a constant r, which means that only θ and φ vary.
firoz.raj
Can anybody explain me .About Rigid Rotator.Kindly let me know the idea.Any help would be
highly appreciated.
I doubt that I can be of any help to you, but I have a request for clarification. Are you referring to a helicopter rotor set, or something else?
Welcome to PF!
highly appreciated.
Hi firoz.raj! Welcome to PF! :smile:
Yes, you really do need to be more specific.
What do you mean by "Rigid Rotator"? :confused:
i need to Understood the following Expression.Kindly let me know step by step.
In most respects the analysis of rotational systems is largely a generalization of the types of coordinates used to describe the system. Schrödinger's eigenvalue equation given above is very hard to solve in Cartesian coordinates because motions in the x,y, and z directions are not independent of each other. Polar coordinates most directly describe rotational motion and allow the Hamiltonian to be separated into independent coordinates. For example, the angular velocity is only dependent on the time derivative of the phi coordinate. To solve Schrödinger's equation we need to convert the Hamiltonian to polar coordinates. Chain rule differentiation provides the means for converting differential operators from Cartesian to polar coordinates.
Angular momentum is a vector quantity that results from the cross-product of the position vector r from the center of rotation with the linear momentum vector p of the particles in motion. Conversion of the angular momentum vector to polar coordinates is given in the following table.
For a rigid rotor r is a constant and the Hamiltonian becomes
ok, I understand now. :smile:
"rigid rotor" simply means that r is constant, and only θ and φ vary.
So when we transform from Cartesian to polar coordinates, ∂/∂r = zero, and every ∂/∂r can be omitted, leaving only ∂/∂θ and ∂/∂φ, as shown in your picture.
Sir,
i need to Give BS(Physics) Final Year examination.i think this is not a Appropriate Explanation
in My Case.Simple r is Const.and only θ And φ will be vary.i need Good Explanation.Sorry this
is really small question but i will ask.Additional if possible kindly tell me any example also for
Rigid Rotator.
FAQ: Some Explanation with Rigid Rotator
What is a rigid rotator?
A rigid rotator is a theoretical model used in physics to study the motion of a system that consists of particles connected by rigid bonds. In this model, the particles are assumed to have fixed positions relative to each other and to rotate around a fixed axis without any deformation or translation.
What is the significance of studying rigid rotators?
Rigid rotators are important for understanding the behavior of many physical systems, including molecules, atoms, and planets. They help us understand the relationship between rotational energy and angular momentum, and how these properties affect the overall motion and stability of a system.
How is a rigid rotator described mathematically?
A rigid rotator is described using the Schrödinger equation, which is a mathematical equation that describes the quantum state of a physical system. The equation takes into account the rotational energy and angular momentum of the particles in the system, as well as any external forces acting on it.
How does the energy of a rigid rotator vary with its rotational speed?
The energy of a rigid rotator is directly proportional to its rotational speed, meaning that as the rotational speed increases, so does the energy of the system. This is known as the rotational energy or moment of inertia, and it is an important factor in determining the overall stability and behavior of a rigid rotator.
What are some real-world examples of rigid rotators?
Rigid rotators can be found in many physical systems, including the rotation of planets around their axes, the rotation of molecules in a gas, and the spinning of a spinning top or gyroscope. They are also used in engineering, such as in the design of turbines or engines that rotate at high speeds.
