I Some questions about baryogenesis
The discussion revolves around the concept of baryogenesis and its treatment in Scott Dodelson's "Modern Cosmology." Key points include confusion about the formula representing the number of protons in a unit volume at equilibrium and its implications in SI units. The conversation also addresses the concept of "freeze-out," where proton creation ceases, and the need for understanding reaction and expansion rates to determine this point. Additionally, there is a debate about the interpretation of baryon density at low temperatures and the relationship between baryogenesis and the imbalance of matter and antimatter. Overall, the complexities of baryogenesis and its connections to Big Bang Nucleosynthesis are emphasized as critical areas of study in theoretical physics.
Barry-O-Genesis
TL;DR Summary
I have some basic questions about how protons and anti-protons are formed.
I'm trying to follow Scott Dodelson's Modern Cosmology. Specifically Chapter 3. Coverage of the subject of baryogenesis appears to be missing from Dodleson's book, so I'm trying to reconstruct things on my own.
This represents the formula:$$n_p[T]=g_p\space (\frac{k_b\space m_p\space T}{2\pi \hbar})^{\frac{3}{2}}\space e^{-\frac{c^2m_p}{k_B\space T}}$$which should be the same as formula (3.6) in SI units. So, my questions are:
1. I'm a little confused about what this number is, exactly. Does this represent the number of protons in a unit volume as long as the protons are in equilibrium with their surroundings? If we're working in SI units, is this the number of protons that I'd find in a cubic meter as a function of temperature (time)?
2. Isn't there supposed to be some event that causes proton creation to eventually stop and for the change in proton density to be governed only by the expansion of space from that point out ("freeze-out")? Don't we need the reaction rate (##\gamma+\gamma=p+\bar p##) and the expansion rate (##H##) to know when "freeze-out" occurs? Where can I find a lucid discussion of this?
3. As I interpret this chart, the number of baryons today should be effectively zero. If the plasma stayed in equilibrium down to the 7 MeV range, then certainly the protons would have been converted into other particles (photons). Yes, I understand the same can be said of antimatter, but it seems like you don't even need anti-protons to make the argument that - according to this formula - there should be no protons (baryons) a ##0 MeV##. Am I reading this chart incorrectly?
Space news on Phys.org
Baryogenesis generally refers not to the "freeze-out" of baryons, but instead to the CP-breaking physics which created the imbalance between normal matter and anti-matter. This is currently an unsolved problem in theoretical physics. This field of study is usually more aligned with high-energy physics than cosmology.
The freeze-out of baryons is part of Big Bang Nucleosynthesis, which Dodelson starts talking about in 3.2. For the purposes of cosmology, it's generally just assumed that there are some number of protons at low temperatures, and at high temperatures there are those protons plus thermal proton/anti-proton pairs (edit: not protons, baryons. Mix of neutrons and protons at low energies). It is those thermal proton/anti-proton pairs that that equation describes, I believe.
As for the dependence upon the expansion, since the thermal proton/anti-proton particles are thermal, their number density is fully-defined by the temperature.
Abstract The Event Horizon Telescope (EHT) has significantly advanced our ability to study black holes, achieving unprecedented spatial resolution and revealing horizon-scale structures. Notably, these observations feature a distinctive dark shadow—primarily arising from faint jet emissions—surrounded by a bright photon ring. Anticipated upgrades of the EHT promise substantial improvements in dynamic range, enabling deeper exploration of low-background regions, particularly the inner shadow...
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
Title: Can something exist without a cause? If the universe has a cause, what caused that cause? Post Content: Many theories suggest that everything must have a cause, but if that's true, then what caused the first cause? Does something need a cause to exist, or is it possible for existence to be uncaused? I’m exploring this from both a scientific and philosophical perspective and would love to hear insights from physics, cosmology, and philosophy. Are there any theories that explain this?
