B Some questions about humidity and storing DVDs in a closed cardboard box
  • B
  • Thread starter Thread starter carlos78
    Humidity
Humidity can penetrate cardboard boxes and plastic bags, affecting the items inside, such as DVDs and electronic boards. When transitioning from a humid environment to a hot, dry climate, moisture may evaporate, but the rate depends on the materials involved. Plastic bags allow water molecules to move at varying rates, influenced by the type of plastic. Paper and cardboard can absorb moisture, acting as a reservoir that prevents condensation. The relationship between humidity and these materials is complex, and understanding it is crucial for preserving items in varying climates.
carlos78
Substandard Post Quality -- Newbie reminded to use better sentence structure, punctuation and paragraphs.
If I have a dvd disk inside those plastic boxes suitable for dvd disks in black, if I have an electronic board inside a bag or papers inside any plastic bag and after that all of them inside a closed cardboard box when I closed the cardboard box or bag or dvdbox it was in rainy or humid weather or even dry but with some humidity but in rainy season the humidity entered the box, bag or dvdbox when that climate is changed from rainy and one gone to hot and dry (31-35C) is the moisture that is inside the cardboard box, inside the bags and inside the dvdbox evaporated or does this only happen if you heat them intensely? that is, does the change to a dry and hot climate dry or not these items of moisture deposited on them?
This is a diffusion question and the time scales depend upon the exact materials involved.
Sentences are a useful part of grammer.
Likes berkeman
carlos78 said:
... if I have an electronic board inside a bag or papers inside any plastic bag ...
Water molecules will move at different rates through plastic bags, depending on the grade of the plastic.
Dry plastic bags are brittle. Plastic is preserved by the presence of excess water, which is a plasticizer for PE.
Paper and cardboard act as a reservoir for water vapour, that prevents local condensation by virtue of the huge surface area of cellulose fibres.
That leads to a complex relationship.
Likes Spinnor, hutchphd and Lnewqban
(Note -- this turns out to be a well known and prolific sockpuppet who seems to have mental fixations on humidity and his DVD/CD collection. Accordingly this latest sockpuppet has been shown the door.)
  • Sad
Likes jedishrfu, Vanadium 50, topsquark and 2 others
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
