Pual Black
- 92
- 1
i have some questions and some of them i can't answer. The questions are form the
"Spectrum Techniques Lab Manual Student Version"
the link for this manual https://www.google.com/url?sa=t&rct...=fpanN3GAbmQv5T4gH_qn-Q&bvm=bv.80642063,d.d24
Lab #1: Plotting a GM Plateau1. Read the introduction section on GM tube operation. How does electric potential effect a GM tube’s operation?
If we increase the electric potential more positive ions and negative electrons will be accelerated to the cathode and anode
2. Will this value (the operating voltage of GM tube) be the same for all the different tubes in the lab?
No it will not because of difference in their construction
3. Will this value (the operating voltage of GM tube) be the same for this tube ten years from now?
No it will not because the gas permanently break down over time ( life time)Lab #3: Background1. Name the four natural sources and three man-made sources of background radiation.
Natural sources: Terrestrial Radiation,Cosmic Radiation, Cosmo genic Radiation
Man-Made Sources: Nuclear reactors and weapons 2. Is there any way to eliminate background radiation?
Radiation has always been present in the environment and in our bodies. Therefore it is impossible to eliminate Background Radiation.
3. Are all the background measurements exactly the same number of counts? Is there a systematic cause for this?
Lab #5: Geiger Tube Efficiency1. How can you determine the activity of a radioactive source?
By using the equation
## \%E=\frac{r(100)}{CKG} ##
Where
r= is the measured activity in cpm minus the background radiation rate
C=is the expected activity of the source in µCi
K=the conversion factor (convert from dpm to Ci) 1Ci=2.22*1012dpm
G= the fraction of the emitted radiation2. Do you expect efficiency to be good or bad for each of your sources? (Consider real-world effects)
The efficiency is related to the kind of radiation (α, β, γ). The best efficiency is get by using gamma particles. 3. Is the efficiency you calculated for each isotope valid only for that isotope? Explain your answer.
The efficiency varies with the type of incident radiation
Alpha particles are not particularly energetic—their source must be kept close to the end window of the G‐M tube, or they will be stopped in a short distance in air. Gamma radiation, itself, has a small probability of ionizing the gas in the G‐M tube because it is detected essentially when it scatters electrons in the metal cylinder surrounding the gas into the tube.
Beta particles that enter the tube have the largest odds of ionizing the gas in the tube.
As a result of these facts, a G‐M tube tends to be much more efficient for detecting beta particles
4. If a different shelf is used, will the efficiency change? Explain your answer.
The efficiency will change since the distance will change and because of the equation
Where
##G=\frac{1}{2} - \frac{d}{2\sqrt{x^2+d^2}}##
d is the distance ( shelf used)
Therefore if d gets bigger the efficiency will be smaller and vice-versa
5. (Correlates if five minute and one minute runs were taken.) Are the Efficiencies different? How different? Why??Lab #8: Inverse Square Law1. Write a general mathematical expression for an inverse square law.
##I=\frac{C}{4 pi R^2}##
2. What are other examples of inverse square laws?
Inverse Square Law, Gravity
Inverse Square Law, Electric
