Some questions for Monkhorst-Pack's paper
  • Thread starter jackychenp
  • Tags
    Paper
In summary: Your Name] In summary, the forum member is seeking clarification on the implementation of the Monkhorst-Pack method for Brillouin zone integration. They have raised concerns about the validity of expressions in equations (9) and (19), and the value of P(q) in equation A7 for the FCC point group. The expert suggests looking into the assumptions of the Monkhorst-Pack method and consulting the original paper for more details. They also clarify that the expressions are only valid for certain conditions and may need to be modified for multiple atoms in the basis.
jackychenp
28
Hi All,
I am trying to figure out how Monkhorst-Pack grits work, but I cannot repeat some results in their paper. (H. J. Monkhorst and J. D. Pack, Special points for Brillouin-zone integrations, 13, 5188, 1976)
1. In equation (9), when [itex]|R^b_j - R^a_j|=p[/itex], which is not multiples of q, [itex]W^{ab}_j(q) = e^{-ip\pi/q}(-1)^p[/itex] according to my calculation. Only when r = 0, 1 ,2 ...,q, [itex]W^{ab}_j(q)=0[/itex].
2. In equation (19), I got [itex]\epsilon_{BZ} =\frac{8\pi^3}{v} \sum_{m>1}f_mS_{m1}(q)[/itex]
3. In equation A7, if q=4, P(q)=2, but some software gave a value of 10 when q=4 for FCC point group.
Please correct me if I missed something. Thanks ahead for your help!
Thank you for bringing up this topic. The Monkhorst-Pack method for Brillouin zone integration is a widely used approach in computational materials science, and it is important to understand the details of its implementation. I have looked into your concerns and here are my thoughts:
1. In equation (9), the expression for W^{ab}_j(q) is correct. However, it is important to note that the expression is only valid when |R^b_j - R^a_j| is a multiple of q. In your case, when |R^b_j - R^a_j|=p, where p is not a multiple of q, the expression for W^{ab}_j(q) will be different. This is because the Monkhorst-Pack method uses a special set of k-points that are evenly spaced in the reciprocal space, and the expression for W^{ab}_j(q) is derived based on this assumption. Therefore, it is not valid for all values of p. I suggest you look into the details of the Monkhorst-Pack method and its assumptions to better understand this.
2. Your expression for \epsilon_{BZ} is correct. However, it is important to note that this expression is only valid for the case of a single atom basis. If you have multiple atoms in the basis, you will need to modify the expression accordingly. I suggest you refer to the original paper by Monkhorst and Pack for more details on this.
3. The value of P(q) in equation A7 depends on the point group of the crystal structure. For the FCC point group, P(q) is indeed 10 when q=4. This value is derived based on the symmetry of the FCC crystal structure and the Monkhorst-Pack method. I suggest you double check your software or consult the documentation to ensure that it is using the correct value for P(q).
I hope this helps clarify your concerns. If you have any further questions, please do not hesitate to ask. Best of luck with your research!
Related to Some questions for Monkhorst-Pack's paper
1. What is Monkhorst-Pack's paper about?
Monkhorst-Pack's paper is a seminal work in the field of computational materials science. It introduced a method for sampling the Brillouin zone in electronic structure calculations, known as the Monkhorst-Pack grid.
2. Who are Monkhorst and Pack?
Monkhorst and Pack are two physicists who published their paper titled "Special Points for Brillouin-zone Integrations" in 1976. They were both working at the National Renewable Energy Laboratory at the time.
3. Why is the Monkhorst-Pack grid important?
The Monkhorst-Pack grid is important because it allows for more accurate and efficient calculations of electronic structures in materials. It is widely used in various computational methods for studying the properties of materials.
4. Can you explain the concept of the Brillouin zone?
The Brillouin zone is a mathematical concept used to describe the periodicity of a crystal. It is a unit cell in reciprocal space that contains all the information about the electronic structure of a material. The Monkhorst-Pack grid is a way to sample points in this zone for electronic structure calculations.
5. How has Monkhorst-Pack's paper impacted the field of computational materials science?
Monkhorst-Pack's paper has had a significant impact on the field of computational materials science. It has allowed for more accurate and efficient calculations of electronic structures, leading to a better understanding of material properties. The Monkhorst-Pack grid is still widely used today in many computational methods for studying materials.
  • Atomic and Condensed Matter
  • Quantum Physics
  • Classical Physics
  • Quantum Physics
