Some questions from the navy oar mechanical comprehension
In summary: The weight itself does not determine the tension, but rather the distance from the ceiling. So in this case, the weight with the greater distance from the ceiling would exert more pull on the ceiling. 33. question about a pulley. I put B since I thought force of gravity would also help.You are correct. The force of gravity would help in this scenario, so the correct answer is B. 34 Which systems requires more rope to be pulled. Do not really get it.This question is asking about leverage. The longer the lever, the easier it is to lift an object. Therefore, the system that requires more rope to be pulled would have a
homeylova223
104
I am looking at the following exam the mechanical comprehension part and I am having trouble with some of the questions. Here is the link
https://drive.google.com/drive/folders/1ITIf6mx4RmDoL96IYoH-eY6-jQPh7CUv.
I am having trouble with the following
3. A woman sits in a dragster the beginning of a race. As the light turns green she steps on the accelerator. At the moment the dragster begins to accelerate what is her weight pushing into the seat relative to while the car was stationary?
a.less than while stationary
b. the same a while stationary
c. more than while stationary
Not sure since force=mass(acceleration). I would say her weight would decrease.
11. Where is the current greater in this circuit?
+A<------(--X)----->--B
a. greater at A than B
b.greater b than a
c. the same at A and B
I think electrons flow from positive to negative so greater than A is my answer.
12. X which has a negative charge is positioned between positive charge A and negative charge B. What direction will x move
A.a
B.b
C. remain where it is
15. the rate of heat exchange is faster
a.between a ice cube and 100 celcius glass of water
b.an icecube and 40 celcius water
c.none of the above
I thought since the colder glass is already cold they would exchange heat quicker because the temp difference is less. But heat exchange is faster when temperature difference is large.
20. This one has a picture in the exam. It basically ask what is hard pedaling a bicycle with large front wheel and small back wheel or a small front wheel small back wheel up a hill?
22. This questions ask two wheels are connected by a chain. Point a is a point on the edge of the large wheel and point B is the point on the edge of a smaller wheel. If larger wheel makes one revolution does point a travel a large distance than point b?
I would say they travel the same distance because point a travels a larger distance but point b travels a smaller circumferance but makes more revolutions.
25.question about anchor I do not get it. I thought point A has more tension because it also has anchor pulling on it.
28. Question about tension. Two weight are hanging by a rope from a ceeling one is only 5 pounds but has a greater distance from the ceeling. One is 10 pounds but has shorter distance from the ceiling. Which one exerts more pull on the ceeling?
I thought it was the heavier one but I am wrong.
It is full astb practice test pdf
Haven't you ever ridden in a car? When you accelerate from a stop, the car pushes you forward so you press back into the seat.
b.greater b than a
There is NO circuit!
A.a
B.b
A negative charge is repelled by another negative charge and is attracted by a positive charge.
c.none of the above
"Newton's law of cooling": Heat flows from a higher temperature to a lower at a rate proportional to the difference in temperature. That is it flows faster when the temperature is larger not when it is less.
Imagine one very large wheel and one very small wheel. You are essentially riding a uni-cycle and it doesn't matter where the small wheel is. There will be no difference.
I assume the chain runs over the circumferences of the two wheels. The distances the two circumferences move is equal to the distance the chain moves. There is no difference.
I have no idea what you are talking about!
[quote\28. Question about tension. Two weight are hanging by a rope from a ceeling one is only 5 pounds but has a greater distance from the ceeling. One is 10 pounds but has shorter distance from the ceiling. Which one exerts more pull on the ceeling?
Why do you say that is wrong? The distance a weight hangs says nothing about the force on the ceiling- that is entirely due to the weight. (Unless there is some kind of torque arm you didn't tell us about.)
What?? I suspect a picture would be useful here.
The picture is the link but let me see I can upload the pdf.
33. Confuses me I thought it would be A because gravity helps.
34. not sure
Here in the original post you correctly decide that the 10 pound weight will exert more pull on the ceiling than a 5 pound weight regardless of rope length.
But in post #5 above, we see a screen shot which says that the actual question is about which weight will exert less pull. Clearly that will be the 5 pound weight.
Sorry I wrote it wrong. I will only post the images now.
Enough already. Proper form is one question per post, done in the homework forum with typewritten work shown, using the template provided.
As @jbriggs444 has pointed out:
Please start a new thread in the appropriate homework forum and fill out the homework template. This thread is closed.
Related to Some questions from the navy oar mechanical comprehension
1. What is the purpose of the Navy OAR mechanical comprehension test?
The purpose of the Navy OAR mechanical comprehension test is to assess a candidate's understanding of basic mechanical and physical principles. This is important for individuals seeking to join the Navy as officers, as they will be responsible for operating and maintaining complex machinery and equipment.
2. What topics are covered in the Navy OAR mechanical comprehension test?
The Navy OAR mechanical comprehension test covers a variety of topics, including mechanics, thermodynamics, electricity and magnetism, and fluid dynamics. It also includes questions on basic mechanical tools and machines, such as gears, pulleys, and levers.
3. How is the Navy OAR mechanical comprehension test scored?
The Navy OAR mechanical comprehension test is scored on a scale from 20 to 80, with a passing score of 40. The score is based on the number of correct answers, with no penalty for incorrect responses. The test is timed, so it is important for candidates to manage their time effectively.
4. What is the format of the Navy OAR mechanical comprehension test?
The Navy OAR mechanical comprehension test is a multiple-choice test, with 40 questions to be answered in 20 minutes. The questions are presented in a random order and cover a range of difficulty levels. The test is administered on a computer and can be taken at a designated testing center or online.
5. How can I prepare for the Navy OAR mechanical comprehension test?
There are several ways to prepare for the Navy OAR mechanical comprehension test. Some options include studying relevant textbooks and practice tests, taking online courses, and working with a tutor. It is also important to familiarize yourself with the format and types of questions on the test to improve your chances of success.
  • Mechanics
  • Mechanical Engineering
