- 6,223
- 31
An insulated piston-cylinder assembly contains air and nitrogen separated by a highly conducting partition. Accordingly, the temperatures of the two gases may be assumed to be equal at all times. Initial Conditions of air are 0.3m3,101kPa, 30C and of nitrogen 0.13,101kPa,30C. Air is compressed 'till the temperature reaches 200C. Determine:
1)The final pressure of nitrogen
2) The amount of heat transfer between them
3) The work done on the air
4)The value of n if the compression of air follows PVn= Constant.
Ideal gas law, PVk=Constant
Q-W=U
Since the piston is insulated, the side containing nitrogen has no net transfer of heat towards the surroundings i.e. adiabatic process.
For Nitrogen [itex]\gamma = \frac{c_p}{c_v}= \frac{1.039}{0.743}[/itex]
[tex]P_1V_1^{\gamma}=P_2V_2^{\gamma}[/tex]
[tex]\frac{P_1V_1}{T_1}=\frac{P_2V_2}{T_2}[/tex]
Combing these two equations I get:
[tex]T_1V_1^{\gamma -1}=T_2V_2^{\gamma-1}[/tex]
[tex]\Rightarrow V_2=\frac{T_1}{T_2}V_1^{\gamma-1}[/tex]
[tex]V_2=\frac{273+30}{273+200}(0.3)^{1.398-1}[/tex]
[tex]V_2=0.397m^3[/tex]
[tex]\Rightarrow P_2=P_1(\frac{V_1}{V_2})^{\gamma}=68.27kPa[/tex]
2) Work done on N2
[tex]W= \frac{P_2V_2-P_1V_1}{1- \gamma}=8.03kJ[/tex]
(this means that the work done by the air on the N2 is also 8.03kJ)
Now [itex]\delta U=mc_v \delta T[/tex]
[tex]m=\frac{P_2V_2}{RT_2}[/tex]
I was given M=25kg/kmol and I know that MR=r where r is the universal gas constant (8.3143kJ/kgK)
such that R=8.3143/(28x10^-3)=296.94kJ/kg
[tex]\delta U= 0.00019kJ[/tex]
(I think my units may be wrong here)
So then by the 1st law of thermodynamics, the heat transfer between air and nitrogen is
Q=0.00019+8.03=8.03019kJ.
This somehow seems wrong to me.
